Need Viper advice
Need Viper advice
Hey guys!
My top speed has dropped,
I put the fin on it = 48mph
Removed jack plate =44mph
Prop is a 23p
Motor is a 115hp mercruiser
Thanks again
Prop is a 23p
Thanks again
- image.jpg (118.61 KiB) Viewed 7379 times
Re: Need Viper advice
Don't be frustrated, working on the set up is half the fun.
It would help to have more info... where is the prop shaft in relation to the pad, what are your rpms, what type of prop?
Could your gear ratio have been changed when the lower unit was rebuilt?
Meanwhile, here's a page that will discuss a lot of Viper set ups http://hydrostream.org/TechTalk/TechTalk.htm
Thanks for the reply!
Prop shaft is about 3 inches below the pad.
Rpms- not sure because gauge just stopped working
Prop is a 23p, 3 blade stainless
And no, I don't think gear ratio was changed.
Thanks for the link, I'll check it out
- Has thanked: 351 times
WOAH!!! Get that motor WAY up. 3 inches below the pad will make that boat handle like poo. Get it up to at least in inch below, and assuming you do not have a low water pick up on that, raise it up until you just start to loose water pressure. You will notice a HUGE difference in the way the boat will behave.ViperMan wrote:Thanks for the reply!
I hate to be the one to ask but has the core (not the floor) ever been replaced in it?
Hey Hippie459MN
thanks for the helpful info, i figured this is a large part of the issues im having. Do you think i should get a 2" - 4" jack plate?
And im honestly not sure if the core was replaced, i assume not, because the previous owner didn't mention anything. Is there an easy way to tell if its had work on?
Thanks again
Thanks again
- Been thanked: 6 times
whoa there, don't jack the motor up just yet, you need to make sure that thing has cooling water to the motor. you can only run the propshaft even with the pad if you have a low water pickup. Do you have a lwp?
Need Viper advice
Get some dual steering on that baby to. These boat need to be driven, when they start getting up on the pad you need to keep it balanced or it will chine walk. Sloppy steering and rubber mounts will also make it hard to control. My valero is fairly easy to keep on the pad but if you dont keep up on the steering it will start to flop around lol
- 31241 Views
Jan 09, 2021 9:21 am
- 138413 Views
Jan 29, 2021 9:17 pm
- 114909 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 193927 Views
Jun 03, 2021 11:12 pm
- 52616 Views
Feb 17, 2021 9:22 am
