How much setback do I need
Re: How much setback do I need
Welcome to the forum .
7" sounds about right. How high are you running it?
So your prop shaft is 1/4 " above the pad. If so that sounds about right, I'm no expert on v-king set up but someone else will be along.
Why are you asking??? If your having a problem we need to know what it is first, But if the set up works for you then it works for you
1982 Hydrostream Vandal
Currently restoring...
well i was told 5'' was the best way to go .but i like very much .I turn 28 yama drag with 1.87 7000 it runs well.
What gps speed are you running, at 10% slip it should be 89 mph.
- 8410 Views
Aug 16, 2023 7:27 pm
- 4846 Views
Dec 24, 2022 7:47 am
- 5863 Views
Jan 10, 2023 8:43 pm
- 4758 Views
Jan 30, 2023 12:07 pm
- 7075 Views
Feb 16, 2023 11:49 pm
