Viper set back
Viper set back
Picked up a nice dry Viper today. Solid as a rock, bought it from a former Hydrostream employee. He gave me a great deal on it.
I am going to put a jack plate on it because I am running a 90 HP Merc inline 6 and the bolt pattern is different from what is on the boat (BIA). I do not want to re drill it.
Should I go with a 3 or 4 inch? I will be using a Vance Mfg. plate.
Thanks, Ron
Thanks, Ron
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
Re: Viper set back
never had a Viper but had 2 Vectors and the less plate the better from my experiences,but I d see what Chet or Sonic say they have Vipers
- Has thanked: 351 times
Re: Viper set back
Chet is running a 4" plate on his if I remember right.
Re: Viper set back
I have a bob's convertable set at 2.5 but the inline is lighter so I would bet you can get away with a little more setback if you need to.
I bought my vking from Pete, nice guy.
Re: Viper set back
I've come to believe that the less horsepower you have, the closer the engine should be to the boat. In the case of an inline, I feel it should be on the transom.
Re: Viper set back
That's interesting. I would assume due to the weight you would want more setback and wouldn't think horsepower would be a factor.transomstand wrote:I've come to believe that the less horsepower you have, the closer the engine should be to the boat. In the case of an inline, I feel it should be on the transom.
Re: Viper set back
I tried for months to help set up a buddies Ventura with an inline. Same package I had years ago. Never could get the boat to air out, and duplicate the same speed. I even sent him the prop I used in 1977, but the thing just wouldn't get up. We never had a chance to test it (he finally just installed a V-6), but by the end, I was convinced it was the set back holding it down.
When we ran inlines, the slower speeds required a lot of positive trim to fly the hull, you had to stand the boat on the back edge of the pad to go fast. Adding set back seems to just drive the pad deeper, and slow it down.
In a V-6 application, it's overcome by the added lift from the increased speed. My boat runs very, very flat now compared to the inline days.
Re: Viper set back
I always thought this was a textbook example of how to fly a Stream with an inline, lots of trim, standing on the rear edge of the pad, and no set back.
Re: Viper set back
T-Stand,
Great info. I don't have much experience with the inlines so it helps. Really the only reason I'm putting a plate on is so I don't have to drill more holes. The transom is so nice on this boat and the splash wells don't even have stream cracks in the gel. I don't want to hurt it and I know plates mean leverage.
I may just go with the 3 inch. It is the shortest they have at Vance and I like the way they adjust.
- 5267 Views
- Last post by russelljwr
May 26, 2010 6:35 am
- 3827 Views
- Last post by jacklake2003
May 25, 2010 9:48 am
- 6737 Views
Jun 24, 2010 7:25 pm
- 3194 Views
May 26, 2010 6:12 am
- 3152 Views
May 26, 2010 8:59 am
