Viper set back
Re: Viper set back
Given the choice of drilling holes, and adding a plate, I'd probably add the plate. Had to redrill my transom for the 15 inch mid last year, and I was cryin for a week.
Re: Viper set back
Did you notice a big difference going to a 15" mid? Run the motor a lot lower anyways.transomstand wrote:Had to redrill my transom for the 15 inch mid last year, and I was cryin for a week.
Re: Viper set back
Biggest thing was to get the motor back down, I was getting uncomfortable with how high the engine was above the transom, and I still wanted the propshaft higher. Drivability wise, I see little change, but the Ventura has always been one of the most well mannered Streams anyway. There may be more benefit with the other models.Hippie459MN wrote: Did you notice a big difference going to a 15" mid? Run the motor a lot lower anyways.
I'm probably not the best "test dummy", I drive like Granny nowadays, but I sure do seem to be wreckin a lot more gearcases
Re: Viper set back
Adds at least 10 mph in "crowd appeal" at the ramp too
Re: Viper set back
Dang that thing looks sweet!
Re: Viper set back
Hey GRANNY do you use .......................AOL........................
Re: Viper set back
RussF wrote: Hey GRANNY do you use .......................AOL........................
Granny is one thing, prehistoric is another
Re: Viper set back
Someday Russ will get rid of AOL.... HaHa
Re: Viper set back
The fact it's trim angle and speed dictating setback makes a lot of sense. Thanks for the explanation.
Re: Viper set back
There was some loose foam bouncing around in the bilge, below the floor. I busted it up and pulled it out. Probably one square foot, 3 inches thick...dry as a potato chip in the Arizona sun. It's a good sign.
1990 HST / 260 EFI offshore
1987 Venus XT/ 200 Yamaha
1983 Viper II 90 Merc. triple
- 2634 Views
Aug 16, 2011 9:17 am
- 10858 Views
Jul 30, 2011 5:41 pm
- 4144 Views
- Last post by braq
Aug 14, 2011 12:02 pm
- 40Replies
- 29507 Views
- Last post by dmottjr
Aug 12, 2011 7:34 pm
- 3496 Views
Aug 02, 2011 12:03 pm
Users browsing this forum: No registered users and 21 guests
