Vector Problem
Vector Problem
I think if I go for a ride like I did yesterday I'll get sea sick! The porpoising on my vector is unbelievable! Can anyone give me some advice! I have an OMC LOOPER v6 on the back if that helps! And the bottom has never been touched!
I heard of putting a straight plate on the motor like a planing foil only wider like 4" by 18"wide would stop it! How true is that?
Almost Don't Count
Re: Vector Problem
We would need more set-up info, then hopefully the Vector owners might start chiming in.
Are you running a jack plate? If so, how far back is the offset? What is your prop shaft position (relative to the pad)? What prop are you running? Is the porpoising limited to a specific speed range?
If you havent seen it yet, Aeromarine Research has a good article on porpoising (see article #15):
http://www.aeromarineresearch.com/articles.html
Re: Vector Problem
i had a vector but have sold it too tnriverrat on here i own an 06 vking now but my vector never proposed bad at all i ran a 28p big ear chopper 200 efi mercury with a hydrofoil and no proposing with 6.5 inch set back jackplate and center of prop 1/2 to 3/4 inch above the pad hope this may help some
Re: Vector Problem
It's 1/4" under pad with hydrofoil! Bobs manual jackplate with 5" or 5&1/2" setback! Right now I have a chopper 26 that I ran! I also have a 30 spenelli but haven't tried it! And it porpoises at all speeds!
Almost Don't Count
Re: Vector Problem
Where is the fuel tank? Try moving weight around. Set the jackplate at 2.5".
[ Post made via HTC A6277 ]
Re: Vector Problem
My V-King had a similar problem. The amount of porpoise decreased as I raised the engine. Also, once I got the boat balanced in run configuration (I.e. with pilot aboard) (side to side) it went away completely.
Re: Vector Problem
My fuel cell is in the back and it's set up in race configuration with pilot in the center!
-Do u mean move the jackplate down 2.5 or in towards the transom?
Almost Don't Count
Re: Vector Problem
Less setback.
Re: Vector Problem
owned a 77 and 81 Vector in the day the 77 had a Merc 175 V6 and the 81 had a Merc inline 6.......NO steback bolted to the transom and no porposing
- 10505 Views
Jul 05, 2018 8:47 am
- 23356 Views
- Last post by msethsmile+
Aug 21, 2019 3:30 pm
New to Hydrostream, so thought I would join forum and network a bit!
Last post by tonymancil « Jul 07, 2018 12:24 am - 2Replies
- 6061 Views
Jul 07, 2018 5:59 am
- 5579 Views
Jul 18, 2018 7:44 pm
- 9469 Views
Mar 06, 2019 11:53 pm
