Page 1 of 3
Trying to set up VKING Yt it's a 2003
Posted: Mar 28, 2017 10:22 am
by Junior stanley
Need help I have 6 inch jackplate 15 inch mid Bob's lwp 1/4 below running a 245 HP carburetor motor only running around ,84 mph I was told I need 10 inch jackplate
Re: Trying to set up VKING Yt it's a 2003
Posted: Mar 28, 2017 2:02 pm
10 inch plate is way to much for a vking and with that 15" mid you could probably get away with a 4" plate.
If it was a vulture or a Vegas I could see a 10" plate for sure but way overkill for a vking.
Also, start with the prop shaft even with the pad seeing that you have a lwp and adjust from there. I know a few guys that end up an inch above the pad.
Posted: Mar 28, 2017 7:30 pm
by Junior stanley
I have been 1/2 above no lift almost ride nose down running a 26 chopper I have trying a few different props now
Posted: Mar 28, 2017 7:31 pm
by Junior stanley
Thanks for the info I will try anything at this point lol
Posted: Mar 28, 2017 8:05 pm
You have a picture of the boat and set up? Where is the battery, gas tank, etc...
Posted: Mar 28, 2017 8:19 pm
by Junior stanley
Posted: Mar 28, 2017 8:27 pm
by Junior stanley
No pictures of set up I have lower unit off getting work done I have pics
Posted: Mar 28, 2017 9:12 pm
Where is your battery and fuel tank in the boat?
Posted: Mar 28, 2017 9:15 pm
Maybe you just need to trim it up more.
Posted: Mar 28, 2017 9:37 pm
by Junior stanley
I have to the
lol
