78 VIKING. GETTING STARTED ON THIS PROJECT.
Why do they use little squares instead of one solid sheet for the cores. ?
Is that the width of the core. Right up to the floor?
eyes on the prize. Will be worth it when its done.[ Post made via Android ]
Anybody thinks this is stupid please let me know before I do it. I can't see a better way there is no lift holes or rings to hook to. I am going to wrap a lift strap around it and pull. [ Post made via Android ]
Did you pull it off already? I made my own bracket. Instead of the Mercury lift sleeve that screws into the flywheel I took 4 bolts out and made a bracket to lift it
- image.jpg (231.06 KiB) Viewed 1854 times
- Has thanked: 353 times
Hey, thats a good idea. I might have to do something like that. I dont have a lift ring for my Evinrude and I need to get it on my boat here soon.
Oh thanks I didn't want to wrap a strap around it and break stuff. I will make one
I didn't know if I should lift on the flywheel I wouldn't have even tried thanks again. Dlord111
I bet your ready for a motor hippie459MN its been a long road.Hippie459MN wrote:QR_BBPOST Hey, thats a good idea. I might have to do something like that. I dont have a lift ring for my Evinrude and I need to get it on my boat here soon.
No problem! I'm glad you didn't use the strap. I don't know for sure if that would have turned out the best. I used 1/4 plate and went to the hardware store and got 4 of the flywheel bolts 1/4" longer so I had all the threads I could get without any play
- 4142 Views
May 23, 2012 7:31 pm
- 6621 Views
Jun 19, 2013 7:38 am
- 5561 Views
May 24, 2012 4:02 pm
- 4671 Views
- Last post by Varigeo
May 22, 2012 8:34 pm
- 4693 Views
- Last post by Sonik
May 23, 2012 11:13 am
Users browsing this forum: Bing [Bot] and 2 guests
