Viper rebuild
- Been thanked: 12 times
Re: Viper rebuild
In need of a Merc cable that is 10' measured distance from the 3/4" barrel at each end. Anyone have 1 layin around?
- DSCF4562 (Copy).JPG (70.41 KiB) Viewed 1796 times
Re: Viper rebuild
Hey Proprider, what's the latest on the viper?
Re: Viper rebuild
With summer here, work on the Viper has slowed. Progress is being made, just haven't updated the thread. Still doing mock-up work on the rigging. Received the tube adaptors and got the holes cut for them. Also acquired the 2" flex tubing that will go with them.
- DSCF4581 (Copy).JPG (111.81 KiB) Viewed 679 times
- DSCF4585 (Copy).JPG (77.98 KiB) Viewed 679 times
- DSCF4689 (Copy).JPG (138.2 KiB) Viewed 679 times
Re: Viper rebuild
Rear light and cleats installed in the splashwell. Glassed in bulkheads to mount the paddle and push/pull pole to. Put them in a position so that they so they could be grabbed quickly....All the seat mounts got fabricated and installed also.
- DSCF4583 (Copy).JPG (114.51 KiB) Viewed 679 times
- DSCF4589 (Copy).JPG (86.05 KiB) Viewed 679 times
- DSCF4604 (Copy).JPG (92.65 KiB) Viewed 679 times
- DSCF4606 (Copy).JPG (106.01 KiB) Viewed 679 times
Re: Viper rebuild
Sweet, I love the build on your viper, what color you going with it
Re: Viper rebuild
Found some nice switches for the trim and jackplate. Had some hardware made to get the helm in order. Mounted the kill switch too.
- DSCF4610 (Copy).JPG (125.49 KiB) Viewed 678 times
- DSCF4615 (Copy).JPG (97.7 KiB) Viewed 678 times
- DSCF4676 (Copy).JPG (60.28 KiB) Viewed 678 times
- DSCF4679 (Copy).JPG (69.2 KiB) Viewed 678 times
- DSCF4617 (Copy).JPG (92.35 KiB) Viewed 678 times
Re: Viper rebuild
Go to the beginning of the thread and check out the video of my hydro race. It will be the same combo.
varmint1 wrote:Sweet, I love the build on your viper, what color you going with it
Re: Viper rebuild
Fuel tank mounts are finished and all the fuel lines plumbed. Arranged it so the primer squeeze bulb is easily reachable from the cockpit.
- DSCF4626 (Copy).JPG (97.37 KiB) Viewed 678 times
- DSCF4627 (Copy).JPG (90.75 KiB) Viewed 678 times
- DSCF4631 (Copy).JPG (87.37 KiB) Viewed 678 times
Re: Viper rebuild
With open stringers, and no subfloor, water that gets into the hull will be sloshing around. Made a baffle that mounts in between the inner/lowest stringers to help collect it in the rear.
- DSCF4638 (Copy).JPG (88.3 KiB) Viewed 677 times
- DSCF4639 (Copy).JPG (122.89 KiB) Viewed 677 times
Re: Viper rebuild
Plumbed and mounted a 500gph bilge pump to get rid of any water in the bilge. Will be manually operated from the helm.
- DSCF4646 (Copy).JPG (88.73 KiB) Viewed 677 times
- DSCF4648 (Copy).JPG (96.84 KiB) Viewed 677 times
- DSCF4650 (Copy).JPG (100.66 KiB) Viewed 677 times
- DSCF4653 (Copy).JPG (89.58 KiB) Viewed 677 times
- DSCF4654 (Copy).JPG (110.66 KiB) Viewed 677 times
- DSCF4641 (Copy).JPG (93.31 KiB) Viewed 677 times
- 31479 Views
Jul 05, 2021 5:14 pm
- 39465 Views
Jul 31, 2021 9:39 am
- 33131 Views
Jul 31, 2021 9:36 am
- 45665 Views
Aug 22, 2021 12:46 pm
- 39247 Views
Sep 22, 2021 8:27 pm
Users browsing this forum: No registered users and 17 guests
