What do you guys think about replacing the core with 2 ounce csm and going over that with a thick woven roven something like 8 to 10 ounce cloth to get rid of all wood except for floor and transom
recore
Re: recore
Other boat builders can get away with this layup schedule because the hull skin is much thicker to carry the loading between the stringers.
Ready,.... ok,.... here we go.......However,.... Performance hulls are much lighter to perform well.
Take a 1/2" thick piece of fiberglass material like in a old hunting bow, while somewhat stiff, it still flexes.
Now take two 1/8" fiberglass skins and seperate them1/2" with a core material. Kinda like a surf board. MUCH more rigid while only using a total of 1/4" of fiberglass.
The further you seperate the two skins, the more rigid the panel is. The panel will only flex if a) the skin tears or b) the core material collapses.
Boston Whalers use this theory in their design. Two thin fiberglass skins seperated by 8# density foam.
Hope this helps.
Hope this helps.
- 3851 Views
- Last post by TNRIVERRAT
Feb 20, 2012 2:45 pm
- 30Replies
- 13626 Views
- Last post by Rut311969
Mar 06, 2012 7:38 am
- 3139 Views
Feb 20, 2012 6:44 pm
new first time hydrostream owner with a blackmax powerhead s
Last post by LongAndLow « Feb 20, 2012 8:13 pm - 2Replies
- 3050 Views
- Last post by varmint1
Feb 20, 2012 9:39 pm
- 23Replies
- 16968 Views
- Last post by smiles
Mar 08, 2012 10:27 am
