This promises to be a long, slow process, as it will be back-burnered for the short term as I need to refinish the family's antique inboard runabout first (1936 Hacker-design twin cockpit 19-footer). But, that won't keep me from occasionally tearing out an occasional piece of rotted wood, perusing eBay for bits and pieces, stockpiling epoxy by the gallon, and, maybe even just sitting in it and making motor noises.
Here are some pics of it the day we picked it up a couple weeks ago.
1977 Hydrostream Ventura II Rebuild & Restore
- She floats - that's a start!
- IMG_1897.JPG (799.11 KiB) Viewed 4366 times
- Pick up day, floating it off the seller's trailer onto mine.
- IMG_1894.JPG (954.91 KiB) Viewed 4366 times
Re: 1977 Hydrostream Ventura II Rebuild & Restore
This will be the motive power - a modern-ish motor (by my standards) in vintage clothing, as the most of the guts will be from the 1980s, a mix of 140 bubble back bits, capped by a 1976 cowling.
- Johnson135_1928.jpg (685.98 KiB) Viewed 4365 times
- A true Johnrude, end result will be a crossflow 140.
- Johnson135_1927.jpg (687.31 KiB) Viewed 4365 times
I dug into it a bit last weekend, removing the homemade benches and the buckets, plus the rear carpeting. Revealed about what I expected - soggy, rotted plywood in place of balsa core, a scabbed on transom repair, and one neatly drilled hole right through the bottom.
- Mush.
- HSVII_4591.jpg (654.67 KiB) Viewed 4365 times
- No surprises - about what I expected.
- HSVII_4590.jpg (579.93 KiB) Viewed 4365 times
- Looking empty.
- HSVII_4592.jpg (875.37 KiB) Viewed 4365 times
- Transom booger!
- HSVII_4593.jpg (814.91 KiB) Viewed 4365 times
Some lovely workmanship there
It occurs to me you'll have to change your name. Venturas don't really chine walk. Other Stream drivers are always pissed at me because they claim I'm just sitting there holding the wheel, while they are working their *** off driving
Actually, that "workmanship" might save me some work in the long run as I've seen some posts about spending days removing stubborn balsa coring. The plywood bits are pulling out in large chunks and aren't really attached to much of anything at all.transomstand wrote:Some lovely workmanship there
As for the handle - I've had that since the 1990s when I was racing Stock Outboard.
- 115416 Views
Jan 29, 2021 9:17 pm
- 91634 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 152228 Views
Jun 03, 2021 11:12 pm
- 41846 Views
Feb 17, 2021 9:22 am
- 34199 Views
Mar 01, 2021 6:53 pm
Users browsing this forum: No registered users and 20 guests
