1980 Viper Rebirth
Re: 1980 Viper Rebirth
Well I had a week off work, but since the house I'm in is for sale, we had viewings and stuff scheduled that interrupted my working time throughout the week. Suffice to say I didn't get as much done as I hoped, but its a start.
First I patched the holes in the pad with some CSM.
Then started laying down the 1.5oz CSM on the hull.
Now due to the nature of laying the CSM and trying my damndest to get the air bubbles out, I did create some clumps and lumps in the mat that the 1708 hates.
I bought a carbide rasp attachment for my oscillating tool and had to grind down the bumps.
18 yard roll of 50" wide 1708 biaxial. When I bought it I wanted 20 yards, but the roll only had 18 on it so I had said screw it. I'll use this for now and if I need more I'll get more later.
So basically I put a strip of CSM up the pad from the transom up the where the "V" starts.
Then I put down (in sections) a layer of CSM over the entire hull, including the transom.
I then added a second layer of CSM on the transom with about 4 inches of overlap on each side.
A couple days later I tried laying the first strip of 1708 and discovered that it hates bumps and pointy sharp sections of mat. That's when I had to grind them all down.
I've got 5 strips of 1708 laid down the pad, with about 2-3 inches of overlap on each strip, from the transom all the way up to the tip of the bow.
1708 on the transom - this was fun....note the sarcasm.
I put a section down on the port side with about 4 inches overlap on the side "wing", and cut at the bottom to go over that curved transom "notch".
Then another piece centred in the transom with about 1 inch overlap on the port piece. Then another piece with 1 inch overlap on the centre and 4 inches overlap on the starboard side "wing".
The second layer was in 2 sections - each starting at the outer edges of the previous motor mounting holes and onto the "wings" right to their respective corners.
Then finally a 3rd layer of 1708 across the entire transom with about 3 inches overlap onto each side wing and the transom notch.
Overkill? Probably. But I want to build this thing like a tank.
Not pictured: On Tuesday I picked up a 4ft x 8ft sheet of 3/4" marine grade plywood (13-ply) for my transom; and two sheets of 4ft x 10ft 3/4" exterior grade mahogany plywood (11-ply) for my stringers and floor.
Hopefully this coming week I can get the rest of the hull covered with the 1708, and then prep for the balsa core bagging.
Both Explorer and chrome won't show the pictures.
Firefox is the only good browser. Internet Exploder sucks, and Chrome just sends all your data to Google.
All pictures working perfectly fine here in MN on chrome on my phone, Firefox and Chrome on my desktop.
Sunday May 13th 2018:
Started laying the 1708 down on the hull. I got the port side done the hard way....folding and wetting out, folding and wetting out, etc.
I tried a different method on the starboard side, and I have to say it was much easier.
With my pre-cut piece laying mat side down, I slathered the resin all over the top (cloth side). I then rolled it onto a piece of 2" diameter plastic plumbing pipe. The excess resin was soaked up by the mat side. Once I had it all rolled up, i moved it to the boat and unrolled it, rolling and squeegeeing out the excess resin as I moved it along.
So now that's done, finally.
Next I'm going to be building a resin trap with a mounted vacuum gauge in preparation of infusing my balsa core. I know i don't need it, but I like doing little projects like this. I've got all the parts for it already, just have to put it together.
I do have several spots in the 1708 with air pockets. I couldn't get them out no matter how much rolling i did. So before I infuse my core, I'm gonna slice them open so they'll get filled with resin under vacuum.
Looking awesome! Can't wait to see the whole bagging set up and process.
Saturday May 26th 2018:
Measured and cut my transom today. Using 3/4" marine-grade 13-ply BS1088 plywood.
Using a straight-edge, I penciled on a 2 inch square grid.
I then proceeded to drill holes as per the grid with a 1/8th inch bit..
I soaked the transom with resin, laid on a piece of 1.5oz mat, wetted that out. Added a second piece of mat, wetted that out..
I soaked the underside of the other piece of transom and laid it on top, getting the edges lined up.
I built 5 clamps using 4x4s and sandwiched 2x4's and 1/2"dia-8" lag bolts.
First I used 1-1/4" drywall screws in the first row of holes to make sure the plywood wouldn't slide as I attached the clamps.
Tomorrow:
-trim the glass edges.
-use a router to cut a radiused edge along 3 sides of the transom (because my transom skin on the hull has a radius along the sides and bottom due to adding glass layers.)
-test fit the transom.
-bond and clamp the transom using ATC Core-Bond.
Tomorrow:
June 2nd-June 6th, 2018:
After letting the transom cure for a few days, it was time to fine-tune the fitting.
I used a circular saw to bevel the bottom edge of the transom to match the angle.
Notice how the top of my transom skin is slightly bowing out. This would be an issue later as I'll explain.
Then went to work on the bottom corners with my grinder to match the contours.
Due to the added glass layers on the transom skin, I had a curved radius along the sides and bottom. I used my router with a 1/4" radius roundover bit. I rounded both edges along the top (to allow easier laying of glass in the future), both side edges (transom skin-side), and along the bottom (transom skin-side)
Once I had the transom fitted as best I could, back on the table it went.
I resin primed the back side...let that sit for 2 hours while it got tacky, then laid on another 2 layers of mat.
Using Scott Bader ATC Core-Bond B72 R (regular), I troweled that onto the transom skin.
And yes, I catalyzed it with 2% MEKP as per instructions.
I constructed 6 clamps with 2x4's, 12" length 1/2" threaded rods, washers and nuts.
For fun, I wanted to see how much clamping pressure I could create.
Tested it on the bathroom scale.
200 pounds, and I figure I could probably tighten it further.
Two days later, I removed the clamps.
My transom skin is a quarter inch thick.....so as you can see, it was really difficult to get the top of the transom skin flush with the new transom. I clamped the hell out of this, to the point where the washers on my clamps started embedding themselves into the wood.
But the gap seems to be maybe 2 inches deep, so I'll have to pick up some large syringes and squirt resin into there to fill the void. And some heavy duty C-clamps to see if I can flatten it.
Next, grinding/sanding down the clumps of corebond, and finishing off my supplies shopping to bag my balsa core.
Looking good.
great work!!
- 6839 Views
Apr 24, 2012 8:24 pm
- 2960 Views
- Last post by blowitup
Apr 23, 2012 10:00 am
- 7123 Views
- Last post by rev.ronnie
May 03, 2012 9:21 am
- 2678 Views
Apr 25, 2012 8:21 pm
- 5073 Views
Jun 16, 2012 4:56 am
Users browsing this forum: No registered users and 74 guests
