Page 4 of 8
Posted: Mar 27, 2017 12:34 pm
by 83VKING
I only have 6 gallons right now. Looks like I will be getting more. The last thing I want to happen is run out in the middle of the job. Rather over buy and have the resin than not have enough. I agree the core will soak up the majority. ideally 65 degrees is good for glassing. I won't see that temp consistently until late May. What is the temperature cut off is for fiberglassing. To realy want to get a goood head start before summer but am not going to risk this crucial part of the job in low temperatures. (Boat is outside no garage)
Posted: Mar 27, 2017 2:09 pm
In not real sure on temperature cut off. I did all my initial glass work in the middle of summer and it was like 90 degrees out side. Second time was in a shop in the middle of winter but he was able to get it from 10 degrees up to 80 degrees no problem in about 20 minutes. LoL
Posted: Mar 27, 2017 8:42 pm
by 83VKING
Nice that's perfect, well looks like i will plan for the warmer weather. in the mean time just need to gather more materials. Thanks!
Posted: Mar 17, 2018 9:06 pm
by 83VKING
Hello!
It has been a whole year since the last time i was active on the form. Lets just say there has been a lot of progress made with this restoration. So much progress that its 100% done and had an awesome summer on the lake in 2017. There where a lot of ups and downs, learning experiences, frustrations, questions, discoveries, and new visions along the way. I plan to post step by step what i did throughout the resto and post the pictures along the way. The way i rebuilt this hydrostream was custom to what i wanted. i used a lot ideas and put them into what i could do. This may not be the top 10 hydrostream resto's out there but i did what i could to bring her back.
i look forward to sharing my resto experience and hope to inspire and bring new ideas to the form. Feel free to be as critical as you want, no hard feelings taken! Looking back, Yes i would do things differently. Lessons learned as you will see when i post the pictures. look forward to sharing my V-King resto!
Posted: Mar 17, 2018 11:47 pm
by 83VKING
Posted: Mar 18, 2018 7:33 am
by RussF
hey your back.......... I live next town from you
Posted: Mar 18, 2018 12:04 pm
by 83VKING
Hey Thanks i remember you are in Litchfield.
After taking out the foam boxes, i started on the transom. 2 pieces on 3/4" sandwiched together with a layer of MAT in-between. Once cured i wrapped it in 1708 Biaxial.
After the glass was dry, i had to sand down the edges and smooth it out.
It was a tough fit. it could oily get it down this far. i had to use a sledge hammer to slam it down.
But it fit nice and snug once it was put in.
I used Loctite PL premium glue as just a filler around the edges and the back against the transom.
I always liked having a build of layered glass at the top, i know many guys like to extend the wood up. i though about it but decided against it because as of right now i do not have a jack plate and the merc 115 would fit as it did from the factory.
resin was poorer down any cracks or seams i could find, then the top was glassed back in because i could, no real reason.
once the glass was hard i was able to belt sand the top and smooth everything out.
i put a few extra layers of glass inside to seal the bond and add a little extra strength. i was going to brace it with the wood from the stringer but had to keep in mind the fuel tank and the very limited space i had to work with. I then turned my focus on the hull and putting a few lays of MAT down before the core.
Posted: Mar 18, 2018 12:23 pm
by RussF
looking good
Posted: Mar 18, 2018 2:27 pm
by 83VKING
Posted: Mar 18, 2018 5:31 pm
by RussF
you should get together with us. there's a group that gets together on the river.....we should be meeting within the next few weeks for breakfast
