Vector build with pics
dbirge hsp839
Has thanked: 2 times
Post: # 22781Post dbirge hsp839 »
So vectors originally came with the floor one level up to just in front of the seats or at the bulkhead. At this point (in the case of my vector at least) there was a slight ledge where the floor raised approx 1-1.5" & finished out under the deck at this height. My question is, could one cut a section of the floor out specifically in the feet area? What i have in mind is like that of the v-king where there is a step down & "foot well" then the step up. Would i be risking structural integrity & strength by allowing this voided floor space duplicating the floor of a v-king or would it make no difference?
1980 vector (under construction) 1983 150 merc 2.0L/1988 2.4L 200 Chrome bore (awaiting assembly)
Been thanked: 72 times
Re: Vector build with pics
Post: # 22782Post AdamDK »
My Viper's 1/2" or 5/8" (i never measured, just a guess) plywood floor "ended" at the foot rest under the dash, as did the fiberglass keelbox. The "floor" past the footrest was just a triangular sheet of fiberglass with no wood structure under it, so it wasn't really adding any strength. However this section of the hull did also have 1/2' balsa core all the way up almost to the bow eye. I suspect the Vector is the same.
So I doubt it would make any difference. The forward "step up" floor in the VKing is also just a fiberglass air box, as you can see.
However, ending the floor at the dash and leaving the forward section just as bare hull means no mounting of hardware, like a HotFoot.
dbirge hsp839
Post: # 22783Post dbirge hsp839 »
i actually just went ahead & put it back as before. Overall im not sure it would have hurt it to leave the foot well. Figured, I've come this far in the process so why leave it to chance. The vector, what i removed from mine anyway, had the floor to the dash like your viper, the step up extending 1"-2" guessing. The ledge was actually in this case the overlapping fiber glassed joint of another 2 feet or so, maybe less, of the plywood floor. Where this short section ends is where the air box started & extended to the bow. My thinking was that as the floor provides a lateral brace support, so to speak, across for the rear section of the hull once glassed in gives strength overall the covered area. I probably gave a little too much thought to it but the more i thought about the more it made sense. As far as im aware & aware of the viper layout i am not; the vector & viper are fairly similar in core placement & floor layout. Though the 2' or so of plywood floor beyond the step up & before the keel box/air box in my vector could be just the difference in the length of the 2 hulls.
Anyway, thanks for the input on the matter!
Has thanked: 349 times
Been thanked: 80 times
Post: # 22784Post Hippie459MN »
Here is how the floor and airbox were replaced in my Vulture. :up:
:boating:
Post: # 22785Post Hippie459MN »
Of course the floor is wider in a Vulture (and Vking) then a Viper and Vector. The Vector and Viper use the same core and floor layout pretty much.
dbirge hsp839
Post: # 22786Post dbirge hsp839 »
Well i have been meaning to post pics of what my vector started out like for some time so here it goes.
Bought it July 2017. "Great Stuff" pics tell all...
20171104_030354 (Copy).jpg (2.84 MiB) Viewed 7214 times
20171104_030338 (Copy).jpg (2.9 MiB) Viewed 7214 times
Finally started the removal process in late October. Grind, scrape, pry a little here & grind some more.
20171115_200419 (Copy).jpg (1.21 MiB) Viewed 7214 times
20171115_200440 (Copy).jpg (1.63 MiB) Viewed 7214 times
20171115_200545 (Copy).jpg (906.67 KiB) Viewed 7214 times
20171115_200549 (Copy).jpg (984.78 KiB) Viewed 7214 times
20171116_072719 (Copy).jpg (2.82 MiB) Viewed 7214 times
20171116_072737 (Copy).jpg (2.47 MiB) Viewed 7214 times
Will post more once i get time to give a little info as to my thought process during some of the process.
Post: # 22787Post Hippie459MN »
Its amazing how much foam is in there once you start digging it out. I wont be putting any foam back in my Vector when I get around to redoing it.
dbirge hsp839
Post: # 22788Post dbirge hsp839 »
Definitely a lot of foam. Wet, heavy foam. I didn't put it back. Planning to use the area they were occupying for a cargo/grocery net type storage. Fire extinguisher, nav lights, small cooler or 2. Thinking about glassing in an insulated cup holder for each front seat. Lots of ideas but one can go overboard & create clutter adding too many extras.
dbirge hsp839
Post: # 23347Post dbirge hsp839 »
Been a long while since i've had a chance to post progress. I have finished the core repair/replacement & had it out several times. The boat rides well & with the 200 chrome bore I built, is a rush. I have had her up to the high side of 92 according to my GPS. Here are some more rotten core removal pics of my vector project
The attachment 20171119_162104 (Copy).jpg is no longer available
The attachment 20171128_182322 (Copy).jpg is no longer available
The attachment 20171129_001846 (Copy).jpg is no longer available
The attachment 20171129_002631_Moment.jpg is no longer available
20171119_162104 (Copy).jpg (2.15 MiB) Viewed 6912 times
