Viking recore
Re: Viking recore
I absoltely love my Trophy Plus. Running 3/4" of an inch below the pad (thats as high as I can go with this jackplate).
Great hole shot, mid range and top end. Also much decreased chine walk than when running my three blade 27 SRX. Running 70 MPH at 6200 RPM with a 24P (using the large size ventilation plugs). I have a tired 150 OMC.
I now have a 26P and 27P waiting to be tried. Try one, I think you will be impressed. I have tried several different props on this boat and always come back to the Trophy Plus (no more running the engine up to 6 grand trying to get an overhub to bite before getting on plane). Hooks up solid the whole way through (almost like a real boat!) )
Re: Viking recore
:ccrick wrote:The thing sounds like an empty beer can and is so light!
Success, Congrats
Re: Viking recore
Thanks surface scratcher. Yea Larry, I guess I need to start a prop collection. LOL. What pitch on the trophy? Anyone using a tempest or vengeance? I see a lot of lazer's pretty cheap. Thanks Rick.
Re: Viking recore
I am running a 24 pitch, but am pulling too many R's with this old cross flow (need to get it down around 5,500).
Was running at 6200 with the 24 pitch (3/4" below and 6" setback). For me I hope 26 pitch will be perfect (havent had the time or weather to get it out there yet). I did run a 27 pitch and it was too much (5,300), and I lost some mid range punch. But, this engine is tired and I plan in upgrading a bit this summer.
So... guess it depends on your max power desired RPM. For calcs numbers I am showing about 7% slip using my tach and GPS. Not sure how accurate the tach is, but envision it is accurate to within 200 RPM or so.
Re: Viking recore
Also, the props are sensitive to the size of the ventilation plugs installed. They have fully plugged, small, medium, large and none-installed. I have had good luck with the large size plugs. Did try the none-installed option, and it ventillated too much. These are also bow lifters, so very little trim is needed to fly the hull (I also have a very light one like yourself). You can usually pick up real nice used ones for around $275.00 or so (a bit more if you need a hub kit).
Re: Viking recore
I just found a laser for 25 pitch for $110.00 I may go look at tomorrow. That'll get the rpms down plus I'll offer the guy 80 bucks or something like that. I run my ventilators wide open, when it bites, it's like second gear
Re: Viking recore
Got the 25 laser2 and rpms in a better range now. Was in the swimmin hole with it yesterday and it floats a lot higher in the water now. better than an inch! Still havent had the opportunity to lay it out yet. It wants to go like hell though!
Re: Viking recore
Waiting to go out solo. The Wife wont no way let me do it with her in the boat. lol :boatThe laser I bought was like brand new. The guy bought it and was to much pitch for his setup and to hard to get on plane. I know one thing, I have to watch the trim its so light. It starts to air with way less pos trim!VultureNo2 wrote:What are you waiting for.... Air it out. Bill
Re: Viking recore
Well, been beating the s*&t out of it this year and it's all holding together. Winter project is a jack and steering. The 2.0 liter is also holding it's own too. Ya can't break it! R's up the kazoo.
- 3685 Views
- Last post by hydrostream76
Jan 16, 2010 6:59 pm
5 Liter Hydroplane Race Boat For Sale - $5000 (Detroit,MI)
Last post by ccrick « Jan 13, 2010 10:22 pm - 1Replies
- 4139 Views
- Last post by ccrick
- 2549 Views
Jan 13, 2010 10:25 pm
- 2905 Views
Jan 16, 2010 8:12 pm
- 4177 Views
Jan 21, 2010 9:34 am
Users browsing this forum: No registered users and 15 guests
