VULTURE 1977 time capsule
Here is my baby I have had it for a few years all original ( except motor of course )
Re: VULTURE 1977 time capsule
Welcome and that is a very nice vulture! My Vulture is a 1977 also.
Where in MN are you from? I notice the MN reg numbers on the boat.
Also, Check this out... Phoogle Maps
some place on the river
Train in the back ground
What do you have ? I would like to find some 150 , 79 or later electronics.
I have a complete 150 with a stuck piston still rotates almost the full revolution with a regular shaft and trim pump lower unit has a nose cone. All electonics are there plus carbs good distributer ect...Also a 125 hp short shaft that runs but needs rebuild.
Is the year post 79. Has it been rebuilt before? I want a true 150 at propshaft which started in 79 with the electronic ignition, coil per cylinder.
kytekeith wrote:Is the year post 79. Has it been rebuilt before? I want a true 150 at propshaft which started in 79 with the electronic ignition, coil per cylinder.
Keith, The Inline 6 150-hp was rated at the crank, 1984 and later Inlines only went to a maxium of 115hp Propshaft hp . If you want 150hp at the prop your goina have to go V6
1982 Hydrostream Vandal
Currently restoring...
- 26427 Views
Jan 09, 2021 9:21 am
- 123233 Views
Jan 29, 2021 9:17 pm
- 96377 Views
Nov 01, 2022 6:49 pm
- 29Replies
- 160787 Views
Jun 03, 2021 11:12 pm
- 43953 Views
Feb 17, 2021 9:22 am
Users browsing this forum: No registered users and 70 guests
