I was in the motor yesterday and was looking at the carbs the top one looks like its open at full but the middle carb looks like it should be more open and i cant really see the bottom one, is there a thread on adjusting or "syncing" these to open them or does anyone have experience on these carbs?
Mercury inline 6 carbs
Re: Mercury inline 6 carbs
There should be a screw on top of middle and bottom carb where the plastic shafts come down from top and middle carb that has a slot, loosen the screw on the middle carb and hold top carb full open ( may need a second set of hands or tie open the top carb) then hold middle carb full open and tighten screw, do the same for bottom carb, also check the plastic shafts for breaks. I hope this helps wish I could send you some pics
Thanks Varmint, I see where the plastic and screw and housing are the plastic looks in good condition im going to give it a go.
here is a pic of the middle carb at full throttle the bottom carb was turned in even more than this i dont know how far off this is im not a mechanic but i adjusted them and they are all straight open now:)
- IMAG0065.jpg (905.79 KiB) Viewed 4087 times
Hope to hear some good results now that your carbs are opening all the way, what size 6 you running
its a 74 115 but it was rebuilt and bored two years its maybe got 50 to 60 hours on it
- 95821 Views
Mar 10, 2022 10:03 pm
- 117369 Views
Mar 25, 2022 2:11 pm
- 118108 Views
- 124337 Views
- 77167 Views
May 22, 2022 8:22 am
Users browsing this forum: No registered users and 41 guests
