Threw a Piston on the 89 150 Black Max 1st time out.
1st time on the water after the 2 year rebuild of the Vulture and threw a piston within 2 minutes. The shop wanted 2000 to rebuild. I asked if they had another motor I might be interested in. Yeah - someone just traded in a 92 Johnson GT200. He said it had one owner and it was babied. Said the guy was afraid to open it up. The guy traded it for a newer engine with less power.
So now I'm a proud owner of a Johnson 200
It will be ready by next weekend. As time permits I wil post some pictures. Hippie, if your going to beat me and get yours on the water, you'd better hurry.
Bill
Bill
Re: Threw a Piston on the 89 150 Black Max 1st time out.
Yeah, I think you have me beat. Its ok though. It will be on the lake soon though. I have faith.
A carb change will turn that Jonny into a 225. You got a bulletproof motor!
Thanks for the comment. I was worried but that's great to know. Can you elaborate. Do you mean replace the carb or change existing? I pick up the baot tomorrow. I'll try to post some pictures or video's as time permits. Bill
From what I am seeing it may just be going from #62D to # 65D jets. If you really want the best carb, get 1998 225 carbs. They have an adjustable idle orifice rather than a fixed jet. It comes in real handy if you want to add Boyeson reeds. Instead of rejetting, you just richen up the idle by adjusting a screw. They are much better carbs than than the 92's you have now. If you make the change, be sure to get the throttle body also. That is where the adjustment screw for the idle is. I havew been around the block with these carbs. If you have more questions, just ask.
http://2strokeonly.com/LOOPER_INFO_HISTORY.html This a link that can tell you more about the loopers. Gary Williams is an expert.
Just to throw this in, I have a '98 225hp with 74D high speed jets. This spins a 27 SRX DAH 6600rpm @ 85mph. I don't recommend this high rpm, and I am having DAH stiffen the prop to get the rpm's in the 6000 range. Here is a link with information on all year looper carbs.
http://www.lmmarine.net/pages/OemParts?aribrand=EVI#/Evinrude/E200STLENS_1992/CARBURETOR_AND_LINKAGE_-_200STL%2c_225_20%22_TRANSOM_ONLY/26579/48680
Between you and Kevin with those darn white motors Just kidding, they are great with a lot of torque for pulling skiers I'm just glad your getting the vulture wet.
I forgot about YOU and YOURS too. Whats a merc man to do?
Oh I guess I shouldn't say to much especially on this thread about mercs. This was today's project 2008 225 opti with 67 hours on it #5 went.
What is the deal with that ?.And I ran Mercs intil the last 2 years there all good except those darn chrysler motors
- 9967 Views
- Last post by ConFuseee
Jan 31, 2011 7:36 pm
- 3123 Views
Jan 29, 2011 1:40 am
- 3521 Views
Jan 29, 2011 5:17 pm
- 9247 Views
Feb 13, 2011 3:05 pm
- 3233 Views
Jan 30, 2011 2:05 pm
