Maintenance free batteries a no-no
Had a tach problem last weekend that points to a bad rectifier on my Rude 225. After doing some research, I am finding that CDI electronics is very specific about NOT using maitenance free batteries for your outboard. They say that the thinner plates prevent the charging system from getting an accurate amperage reading, causing an overload that blows the rectifier. Further, they say that stators are not really designed to recharge a battery, just maintain a charge, and that your battery should stay on a trickle charger, or be fuuly charged before using, to avoid expensive parts failure. I was not aware of ths, so now I have to not only but a new rectifier, but a new battery and charger as well. I hope this may help someone from learning the hard way, like I have. This problem came up after installing an electric fuel pump, that will drain a battery at idle rpm's. I believe I will change to an interstate marine battery, and get rid of the Autozone marine battery I just bought in the spring.
- 3108 Views
- Last post by AFR
Feb 07, 2011 7:17 pm
- 3329 Views
- Last post by DreamStream
Feb 12, 2011 10:45 pm
- 3864 Views
Oct 17, 2011 3:36 pm
- 38Replies
- 32598 Views
- Last post by TREVCO
Dec 19, 2015 12:17 pm
- 3741 Views
Feb 12, 2011 7:29 pm
