Lower unit ?'s
Lower unit ?'s
Hey guys, from what I can see who ever put my lower unit on did a horrible job on the putty end. I want to sand it down and make it smooth. What type of putty or bondo type stuff do you guys recommend? Thanks in advance
Re: Lower unit ?'s
Duraglass is pretty much industry standard, has short strands of fiberglass in it for strength, Bondo type products are just powder, and don't hold up well. Grind off all the old stuff, rough up the case with 36 grit, and sling away. You'll probably need some putty to smooth it out for the final product before priming and painting.
Re: Lower unit ?'s
Good deal thank you. Turns out I can get that stuff through work for $38 a gallon.
Re: Lower unit ?'s
Ok since I'm finally going to do this I've got the Duraglass what kind of putty/epoxy would you recommend to smooth it up with?
Re: Lower unit ?'s
Evercoat polyester glazing putty should be fine.
Re: Lower unit ?'s
transomstand wrote:Evercoat polyester glazing putty should be fine.
evercoat also makes a filler with glass mixed in called "everglass"
i used it last time and it spread and sanded great. have had zero problems
- 4325 Views
- Last post by frogII
Mar 05, 2010 10:39 am
- 2659 Views
- Last post by ccrick
Mar 05, 2010 1:24 pm
- 3902 Views
Mar 07, 2010 12:55 am
- 90Replies
- 163300 Views
- Last post by Hydromirk
Dec 22, 2013 4:45 pm
- 3762 Views
- Last post by shellyisland
Jul 13, 2010 4:12 pm
