picked up a 89 AE-21 with a 91 225 Yamaha,boat looks great and is solid,drove around ,great ride and feel,couple of questions?
top speed is 74 mph gps and 5500 rpm,is that right?
- has a 26 p chopper prop
- what is max rpm on that engine?
-it has dual cable steering,was thinking on a Hydrolic system?
AE-21 help
AE-21 help
- 3.jpeg (62.92 KiB) Viewed 4412 times
- 2.jpeg (49.42 KiB) Viewed 4412 times
- 1.jpeg (71.87 KiB) Viewed 4412 times
1889 Canandian Edition AE-21
1998 Mariner Super Mag 300
10 inchHyd jackplate
Re: AE-21 help
Check out "jupiter valero's" a-21 in the "props, setup, and rigging" section. Some good info and he might be able to help out.
Re: AE-21 help
There is a lot more speed in it but you need to buy some parts. A jack plate and water pressure gauge would be a good start, raise the motor and you will pick up rpm's and speed until you run out of water pressure. Then it's time for a low water pickup.
Like what ydo said jupiter has some info on his that will help out.
Great looking hull though
Re: AE-21 help
After reviewing your pictures above you first need to add a hyd. jackplate and increase your setback to about 12". You'll need low water pickups and a nose cone. Make sure you have a good water pressure gage and temperature gage. Your new setup should yield speeds well into the mid to upper 80's..maybe even 90+.
1991 Canadian Edition AE-21/Merc 2.5
1997 Checkmate Pulsare 2100/under the knife
1994 Checkmate Pulsare 2100/Merc 225Xri-SOLD
1988 Valero YT Bowrider/Merc 175-SOLD
Re: AE-21 help
thanks ,it has a hyd jackplate,just need to get a set back,what think off hyd steering?
Re: AE-21 help
I have hyd steering on my vegas and my viper and love it, I'm trying a cable and pulley system on my vking.
Re: AE-21 help
Going old school!77viper wrote:I have hyd steering on my vegas and my viper and love it, I'm trying a cable and pulley system on my vking.
- 47345 Views
Oct 10, 2021 9:14 am
- 41484 Views
Oct 29, 2021 9:24 am
- 42111 Views
Dec 05, 2021 12:14 pm
- 29164 Views
Nov 02, 2021 5:15 pm
- 18850 Views
Nov 02, 2021 5:18 pm
Users browsing this forum: No registered users and 118 guests
