I've been in love with streams since I was a kid and looked forward to the January boat show every year in Minnesota to see the beautiful glittering hydrostreams with the Merc 150's bolted to the back. I've owned a Volero YT hull in the past, but just purchased a Vector with a 150 Merc for $1500. I have a question about the core on this boat. The transom is in great condition and the core appears to be intact, but it seems odd to me that the core is hollow. The previous owner had replaced a portion of the floor, so the first thing I did after purchase was to pull the floor. What I found was a fiberglass core that is hollow and am wondering if that is how it's supposed to be. I've attached pics. Can anyone help?
Thanks in advance!
Question About Core???
Re: Question About Core???
I responded to your thread on S&F but the core is most likely rotten away.
I have Hippies vulture in the middle of a new core in my shed if you want to drive down and check it out some time.
Welcome to the forum.
For some reason, this site won't let me attach the pictures. I'll respond on S&F.77viper wrote:I responded to your thread on S&F but the core is most likely rotten away.
You can upload/attach pictures here but there is a file size limit. The best option to use is photobucket as they will automatically resize larger images that will work here or you can read the guide posted here.
Here is the reason for the file size limit...
How to upload/post images easily
And
How to resize images the easy way
Hope that helps. We are working on a way to resize images on the server side but for now these are the best options.
Here are some things from the Knowledge Base that should help.Second is that I will be turning the allowed files size way down for uploading images as a lot of people are uploading huge size images and its taking a really long time for the images to load in posts and its doing a number on load times when on mobile devices. The new limit will be 1MiB (1 meg) per image. The image can be as big as you want dimension wise as long as it is under that file size of 1 MiB.
And
- 11537 Views
May 27, 2009 4:59 pm
- 11443 Views
May 27, 2009 11:59 pm
- 11061 Views
May 29, 2009 11:36 am
- 18369 Views
- Last post by Maple Leaf
Jun 07, 2009 9:06 pm
- 19438 Views
- Last post by Vegas XT
Jun 09, 2009 3:30 am
