Replacement rub rail and windshield
I know this has been asked many times but I'm looking for some too. Does anyone still make the black rubber rub rail that fits over the factory aluminum rail? What about a replacement Vector windshield ? I thought about bonding the top deck to the hull and filling the rivet holes and just use some of the black push on edge trim . Has anybody tried it that way?
Re: Replacement rub rail and windshield
Rubrail cover (black)
McMaster Carr
Part # 24175K32
$3.00 a foot
50' needed for Vking (example)
*easy install
McMaster Carr
Part # 24175K32
$3.00 a foot
*easy install
ok ... I ordered the black molding cap that covers the factory alum rail any other silicone or glue tricks when it is attached. I saw a hydrostream on here I believe was done looked great I thought it was a newer boat.. gary p
Anyone no of a rubrail that takes the place of the factory one (black push on)?
if you took the factory off and just glassed the seam.....i bet you could use the same style rub rail that pops "over" the factory rail...just get a smaller one.
i.e. this pop over rub rail is 5/8" tall (i think) ....you could try 1/2" ...they make all kinds of dimensions of it mcmaster carr carries. they send you samples of any of it if you ask...thats how i found the right size to pop over............. maybe hold it on with a good oil based silicon.
the pop over type has a metal rib cage inside rubber coating.....it isnt a great shock absorber though.....
i wanna say spaeth has done this technique on some of his streams
Thanks for the info,Will be at John Spaethes shop in a couple weeks.Gonna ask what he used when he built the hook nose streams.
- 6489 Views
Jul 10, 2020 6:01 am
- 6890 Views
Nov 16, 2020 9:37 am
- 5466 Views
Jul 11, 2020 6:25 am
Amount of gel coat to cover hull and deck of a valaro or v -king
Last post by coffeeguy « Jul 18, 2020 7:43 am - 3Replies
- 5943 Views
Jul 22, 2020 4:24 pm
- 13184 Views
- Last post by 1BobandLossi
Jul 19, 2020 2:25 pm
