Partial recore on a vector maybe.
Re: Partial recore on a vector maybe.
Click on the attachments tab below the posting box.
You need to click on the "Full Editor & Preview" button to see the attachments tab. It's not visible under Quick Reply.
- IMG_20180611_205004115-1503x2672.jpg (838.36 KiB) Viewed 7757 times
- IMG_20180611_210151784-1503x2672.jpg (993.42 KiB) Viewed 7757 times
Got all the bad wood out. Drilled 20 holes into transom only one was damp. Polished it up with poly floor polish. Stringers are Rock solid. Was planning on laying up a layer of glass Matt after the grinding and sanding was done. I have one place where I went too deep and I can see gelcoat from inside.. then laying marine grade plywood in bottom. For the very center. Then glass again then another layer of ply between the stringers. Glass again. Glass over stringer tops. Rebuild seat box and glass it in. Prime and rattle can it.
Aldo I'm probably going g to have to have the trim pump rebuilt. It's slow as all hell. But maybe it will work better when I finish the rewiring. Steering is kind of dragging but not bad.
I think this is a vector title only says hydrostream
- 4129 Views
- Last post by LSaupe
Jan 29, 2013 7:55 pm
- 14456 Views
- Last post by silkeysak
Mar 21, 2013 9:34 pm
- 3310 Views
Feb 10, 2013 6:00 pm
Looking for a Viper with Mercury power/Recore not a problem
Last post by specter76 « Jan 31, 2013 9:28 am - 4Replies
- 4054 Views
- Last post by specter76
Apr 04, 2013 1:58 pm
- 8228 Views
- Last post by Bayou Native
Feb 11, 2013 9:21 pm
Users browsing this forum: No registered users and 118 guests
