splashwell corner CRACKED again!
Re: splashwell corner CRACKED again!
I know it is pain, but I have seen a lot of finished become unfinished with these pesky cracks at the corners. the only way I have found to fully cure this, is prior to paint or gel, LAY A COUPLE LAYERS OF, SAY, 3 OR 4 OUNCE S-GLASS IN THE DIRECTION OF THE STRESS (PARALLEL TO THE BOAT SIDES) AND A LAYER THAT IS ORIENTED ABOUT 45 DEGREES LEFT, AND THEN ANOTHER RIGHT. THE TRANSOM WILL BE A LITTLE THICKER, BUT NOT MUCH, AND YOU WILL HAVE A GREAT DEAL MORE STRENGTH ON THE SKIN, WHICH IS WHRE THE STRESS REALLY OCCURS UNDER POWER. START THE GLASS IN THE SPLASH WELL AREA AND WRAP UP AND OVER ONTO THE OUTSIDE SKIN OF THE TRANSOM. BY USING THESE THIN LAYERS, THE GLASS IS EASIER TO LAY IN PROPERLY WITHOUT THE NEED FOR A LOT OF VACUUM BAGGING. YOU CAN SIMPLY PUT BRICKS OR WHATER ON TOP TO HOLD POSITION AT THE SHARP ANGLES.
- 4859 Views
- Last post by streamin_demon
May 08, 2012 4:43 pm
- 2278 Views
- Last post by actmobmar
Jan 23, 2012 10:34 am
- 3883 Views
- Last post by max94
Dec 05, 2011 7:59 am
- 3098 Views
- Last post by silkeysak
Dec 18, 2011 12:24 pm
HydroStream V-KING-YT with a 2011 Mercury OptiMax 200 XS ROS
Last post by Dmick « Dec 08, 2011 2:39 pm - 5Replies
- 4389 Views
Dec 09, 2011 4:21 pm
