Finally getting around to do the core, transome and floor in my dads Varmint. The question I have is why do you need to put core in the wing area, the Vking,Valero, vultures and other one don't have it there, couldn't I lay a couple extra layers of glass in that area and it be ok
Core in wing area
Core in wing area
I posted this a couple of years ago, I hope someone knew the answer.
Re: Core in wing area
And a couple years later....
my 1980 Viper had core in the wings; naturally it was rotten to the point that you couldn't distinguish it from soil.
I'll be replacing the balsa core with new balsa core, in all areas as it was built originally.
The "wings" generally don't have the stresses of weight or hydrostatic pressure, so I think you could probably get away with just adding layers of glass.
Core is definitely needed on the running surfaces however.
Yes, the varmint, vector, and viper all use the same core structure and must be replaced as such. The hull of the vking and vulture are a little different so core is not required further up like on the viper, vector, and varmint.
- 3813 Views
- Last post by LSaupe
Jun 18, 2010 5:26 am
- 3562 Views
- Last post by JUPITER VALERO
May 06, 2010 8:20 am
- 4253 Views
- Last post by RedDemon
Aug 31, 2010 9:38 am
- 2508 Views
- Last post by hydrohellion
Apr 29, 2010 1:41 am
- 20Replies
- 11853 Views
Nov 13, 2010 12:14 pm
Users browsing this forum: Google [Bot] and 15 guests
