Foam core installation
I am re-coring my 74 Viper. I may use a foam core. Can it be done with-out vacuum bagging? How hard is it to do compared to a balsa core. Does some-one have pictures or video of it being done.
Chazz
- Been thanked: 6 times
Re: Foam core installation
I have found that most guys on this particular forum tend to go balsa after doing some reading about the core materials. It seems the balsa can be a very good core material when laid up carefully. I am also interested in the foam core, but I found it more affordable to do the balsa. As far as vacuum bagging, you might find more input on screamandfly.. Sorry I didn't provide any good advice for the foam core, I haven't had that much experience building boats (Just what I have accomplished so far on my viper).
I have done both. I don't bag due to expense and possible catastrophic results if the seal breaks and the resin kicks.
They lay up the same.
Balsa is a great core material. It gets a bad rap due to bad installation. This is the re-core I did that is on the IHR: http://hydrostream.org/ArticleArchives/AlaskaViperResto.htm
I took a lot of time documenting the whole process explaining what materials and why they were used.
- 6654 Views
- Last post by max94
Sep 10, 2011 7:10 pm
- 4140 Views
- Last post by JUPITER VALERO
Nov 03, 2011 9:51 am
- 3312 Views
- Last post by braq
Sep 10, 2011 11:13 am
- 2483 Views
Sep 10, 2011 10:10 am
- 2466 Views
Sep 10, 2011 10:13 am
Users browsing this forum: No registered users and 14 guests
