Recore on 1987 Valero yt
- Has thanked: 2 times
Hello,
I picked up a Valero yt that needs to be recored and side sponsoon's look waterlogged.
Had some question or would like some advice and pics from anyone who has experience with this or similar build.
Re: Recore on 1987 Valero yt
The Valero's hull is the same as the VKing (just the deck is different).
So any Valero YT / VKing YT restoration threads on here might help.
eg:
http://www.hydrostreamforums.com/viewtopic.php?f=13&t=2774
(although, this guy used transom compound as "core". Not sure how that's gonna hold up...)
One main problem you may run into here, and on other forums, is that a lot of threads had images hosted on Photobucket...and those images no longer work because PB are money-hungry extortionists.
eg:
Hi Mike
The hydrostream.org site is hosted by this site and has some good articles under feature topics. I wrote a re-core article and explained in great detail with lots of pictures. I also showed the equipment and materials used. Hope this helps. This is on a Viper.
http://hydrostream.org/Topic.htm
Additionally, I just finished building a Virage with the XT hull. I bought the hull bare with no foam in the sponsons. I cored my sponsons and didn't put foam in.
Feel free to ask questions.
Thank You very much for responding. I will definitely check out your article and probably have some questions. I am putting this build on hold for now until work slows down a little.
Mike,
What signs did you see to make you think your sponsons are waterlogged?
I’ll get Phil on this thread, he has a Valero also.
One thing I noticed on my Virage. The inside walls of my sponsons were thin and the foam was an easy way to stiffen them.
Without the foam, coring was my best option.
Subscribed mine is a Valero Yt hull. But at least your in good hands with the fiberglass king Roostertail
When I pulled the floor up the fiberglass over the port sponson had delaminated near the transom . When I press on it it seems water like a wet sponge.
Did you also core the sides of the sponson or just the bottom? Did you frame the sponson to strengthen it or does the core take care of that?
Thank You for your advice.
Yes the inside walls of the sponsons were thin and flexed. I cored all three sides of the sponsons..
That’s why they used foam.
I’ve seen guys add bulkheads to stiffen the sponsons but you are creating stiff points which aren’t good.
There’s an active thread on core bond putty vs fiberglass diy putty. Check it out.
- 34514 Views
- Last post by king gill
May 17, 2009 5:35 pm
- 47097 Views
- Last post by Vegas XT
May 20, 2009 8:04 pm
- 17305 Views
May 21, 2009 7:48 pm
- 11539 Views
May 27, 2009 4:59 pm
- 11443 Views
May 27, 2009 11:59 pm
