Black Gel Coat
Black Gel Coat
How do I keep 26 year old Black gel coat looking good? Boat was a trailer queen when I bought it ten years ago and looked new. It still looks good but is fading on the top where it is exposed to the sun. I have a shop now and would like to spend some time/ money getting her back in shape. Any suggestions are appreciated!
SSMVEGAS
Private message
SSMVEGAS
Private message
Re: Black Gel Coat
Wet sand the gel starting with 600 if it's real bad then work up to 2000 then buff with a wool pad and buffing compound then buff again with a foam pad and a lighter finish cut. After your arms are ready to fall off wax with a good wax and keep it waxed to keep the shine.
This is my boat that has new gel but just went through the buffing process.
Re: Black Gel Coat
Do I need to wet sand by hand or can I use a 6" grinder with pads? What are the best compounds to use?
Re: Black Gel Coat
I like 3M they have always worked well
if it's not too far gone you can get by with just a good compound
Re: Black Gel Coat
No...it's not to far gone, just begining to see some cloudy areas and want to take care of it before it gets to bad!!!
Re: Black Gel Coat
Try just buffing a spot and see how it turns out. I agree 3m is all I will use. If you need to sand do it by hand it will go fairly quick.
Re: Black Gel Coat
I have had real good luck with 3M "Marine Restorer & Wax". Its a 1 step process. Part # 09005. I usually give it a good wax coat after for good measure though.
Re: Black Gel Coat
77 VIPER- Your boat looks great and I can hardly wait to see it done! I have some 3M Restorer that I'll try just need to get a good buffer. Do you guys have a preference when it comes to pads/ wheels?
Re: Black Gel Coat
Gel is a lot thicker than paint or clear coat, that's why you can get away with 600 if it's bad. We have a young kid working as a cleaner for us and after buffing a couple glass boats he tried to buff a aluminum boat and found out quick he needs to be careful.
- 15Replies
- 5083 Views
Jan 24, 2011 10:49 am
- 1908 Views
Jan 05, 2011 10:57 am
- 21Replies
- 5144 Views
- Last post by AndyBean
Jan 27, 2011 7:14 pm
- 5337 Views
Jun 12, 2011 8:59 pm
- 44Replies
- 11255 Views
- Last post by ConFuseee
Mar 04, 2012 6:39 pm
