I see this quite often and thought I should share it in hopes of saving some headaches or a powerhead. If you are running Mercury gray fuel line and it's 2 years old or older replace it with ethanol safe line. The old fuel line has red writing on it and the new stuff has blue writing. What happens to the old line is the inner liner comes apart and will cause a fuel restriction and will cause a lean condition and we all know where that can lead. The bad part is it looks fine from the outside but inside it looks like this
I know they are crappy cell pictures but you get the point. I had a guy drive from Canada "about 10 hours" because of this.
check your fuel line
Re: check your fuel line
Good Advice! I've added a clear in-line fuel filter so I'm able to "see" any problems. It came in handy this past spring when I noticed phase-seperation in my E-10 fuel left over from the fall.
good info chet. ive always been a 3/8 black rubber line from the parts house kind of guy, but i think we have that grey on our g-3 ill have to check that out
- 8674 Views
- Last post by vking Bear
Apr 22, 2015 12:03 am
- 12227 Views
- Last post by tommy
Jul 19, 2015 9:13 pm
- 20244 Views
Apr 04, 2015 2:01 pm
- 16167 Views
- Last post by transomstand
Apr 11, 2015 8:42 pm
- 55Replies
- 62466 Views
Sep 16, 2019 6:48 pm
