I need some advice on wetsanding, I purchased this Vulture 6 weeks ago, I have my hot foot in, jack plate on, trim ordered.
Now i need to do some wet sanding.
Boat is really in good shape for 1985, but does have some area's that need attention, mainly on rear sides and a little on the bow area.
Any help is appreciated.
Eric
p.s. She will be helping with wet sanding....
Wet sanding my Vulture
Re: Wet sanding my Vulture
on the ruffer spots i would hit with 1000 and then go up in size slightly till you get it up too around 1300 or till theres harly no scratchs left and keep the watter hose in your other hand the whole time done put the water hose down till your done and whats the cardboard your doing there for a winshield iam interssted in this iam need one also i started messing with one a little bit but never no success
Call me
Eric
260-413-7912
Eric
260-413-7912
265mercman wrote:on the ruffer spots i would hit with 1000 and then go up in size slightly till you get it up too around 1300 or till theres harly no scratchs left and keep the watter hose in your other hand the whole time done put the water hose down till your done and whats the cardboard your doing there for a winshield iam interssted in this iam need one also i started messing with one a little bit but never no success
I have started with 600 then 1000 and buffed with a wool pad after. Then a gray foam pad followed by a yellow polishing pad. Once it looks good keep a good wax on it. UV rays are what destroys the gel I use 303 on my carbon fiber to try and keep all that I can away.
Chet. where can I get gray foam pad and the 303? Is it a wax?
Thanks
Thanks
77viper wrote:I have started with 600 then 1000 and buffed with a wool pad after. Then a gray foam pad followed by a yellow polishing pad. Once it looks good keep a good wax on it. UV rays are what destroys the gel I use 303 on my carbon fiber to try and keep all that I can away.
Any parts store will have the pads, aerospace 303 is a spray wax most marine shops have it.
[ Post made via HTC A6277 ]
I use 1000 grit followed by 1200. Then I use 3M Finness with a high speed wheel followed by Starbright cleaner wax. The last coat is Maguires Marine Wax.
- AE-21 RR PARKING LOT.jpg (100.77 KiB) Viewed 6630 times
1991 Canadian Edition AE-21/Merc 2.5
1997 Checkmate Pulsare 2100/under the knife
1994 Checkmate Pulsare 2100/Merc 225Xri-SOLD
1988 Valero YT Bowrider/Merc 175-SOLD
- 58941 Views
Nov 22, 2021 5:08 pm
- 64861 Views
Oct 10, 2021 9:14 am
- 56810 Views
Oct 29, 2021 9:24 am
- 57544 Views
Dec 05, 2021 12:14 pm
- 39320 Views
Nov 02, 2021 5:15 pm
