32 1/2 cc heads what fuel type
come across a set of 32 1/2 cc heads for cheap i bought them but be for install want to know what kinda fuel can i run compression should be around 150 95 200xri mercury outboard my compression rite now is 120 on all 6 cylinders
Re: 32 1/2 cc heads what fuel type
any help here thanks want to install b4 sat and if i have to run higher octane above 93 is there special way or diff way i have to mix my oil in the fuel
Fresh 93 would be the very least I would run, a little race fuel mixed in sure wouldn't hurt. No need to mix oil any different.
okie thanks got them in stalled 140 psi acrosses the board had 135 on two cylinder which was on port and the other on starboard it started up fine and ran out clean reved really quick also much faster so i think iam good thanks for the reply
- 11290 Views
Sep 11, 2015 8:09 pm
- 11620 Views
Sep 07, 2015 10:51 am
- 11999 Views
Sep 07, 2015 11:40 pm
- 7586 Views
- Last post by Streamer
Sep 09, 2015 8:05 am
- 5528 Views
- Last post by terry2
Oct 03, 2015 10:09 pm
