still overheating
Re: still overheating
the water pickup seal worked. i now have 10-11 psi at idle. it drops to 7 as i rev it. not sure why? ive ordered a whole waterpump assemebly. might as well start with all new parts. ill have to weight till saturday for a test run, it gets dark at 6:00 when i get out of work. thanks for all the help and suport, mike
The poppet valve opens at about 1800 rpm, should drop the pressure about 10 psi
im not sure what a poppet valve is, what it looks like, or where it is. when it drops the pressure about 10 psi, does that mean it regulates the pressuer at constant 10 psi, or does it drop it 10 psi from where it is at 1800 rpm? does the pressuer change with rpm? what pressuer should i have while runninig? i dont know if it makes a differance, but here in florida most of us dont run t-stats.transomstand wrote:The poppet valve opens at about 1800 rpm, should drop the pressure about 10 psi
tx mike
When your running the lwp also forces water to the engine.
It drops it about 10 psi, to prevent excess pressure at high rpm. Thermostats regulate pressure in a stock motor, and should never be removed. Having no thermostats makes it extremely difficult to keep the block full.fla.viper wrote: im not sure what a poppet valve is, what it looks like, or where it is. when it drops the pressure about 10 psi, does that mean it regulates the pressuer at constant 10 psi, or does it drop it 10 psi from where it is at 1800 rpm? does the pressuer change with rpm? what pressuer should i have while runninig? i dont know if it makes a differance, but here in florida most of us dont run t-stats.
tx mike
- 20Replies
- 17461 Views
- Last post by almightygimp1
Sep 02, 2011 8:57 am
- 15Replies
- 19997 Views
- Last post by hydrohellion
Jun 20, 2016 12:03 am
- 12972 Views
- Last post by zizziz
Apr 22, 2014 10:42 am
- 6330 Views
Dec 01, 2011 8:36 pm
- 4018 Views
Sep 02, 2011 7:15 pm
