1973 ventura 1
1973 ventura 1
guys can anyone suggest a prop for my ventura 1.it has a 115 merc inline 6 and i want 70 mph.
thanks scott
thanks scott
Re: 1973 ventura 1
I don't know what a 115 i6 is capable of, but a 26" prop spun around 6500 should get you there... Someone with i6 knowledge would be a better source of info though.
Re: 1973 ventura 1
idvette,
i have 300 hundred acres in parry sound on blackstone lake my great grandfather bought in 1929 for 900 bucks.i gew up there waterskiing and snomobiling.
Re: 1973 ventura 1
Cool, that's not far from me!
Re: 1973 ventura 1
I know a 115 with 25 pitch on a varmint gets 50, I would suggest getting a 150 powerhead so you can run a bigger pitch without bogging the engine. The 25 I ran was very slow getting out the hole so going any bigger probably won't even get on plane. Also I had a lot of porpoising, went to a bigger engine and I can run seventy easily.
Re: 1973 ventura 1
You'll need to raise the motor about 4-5" above the transom, a 26 small ear Chopper will put you at 70 mph. This assumes the engine is a 115 rated at the prop. It will be difficult to drive without dual cable steering and a foot throttle, solid motor mounts would be a plus, but are not essential, as long as the existing mounts are in good condition, a water pressure gauge is a must have. NO JACK PLATE, the boat was designed to run with that size motor bolted to the transom using what woud be considered a lot of positive trim by todays standards. You should also be wearing a competition life jacket and the boat should be equipped with a kill switch. Following this advice will allow you to have more fun with your clothes on than you thought was possible.
Re: 1973 ventura 1
where can i get the prop and how do i know the rating of this engine?do you know a i6 guru?how many of the ventura 1's are left i can't find any for sale
Re: 1973 ventura 1
Pete why won't a 115 push a varmint that fast
- 39Replies
- 272236 Views
Jan 06, 2023 1:17 pm
- 74400 Views
Sep 22, 2021 8:27 pm
- 58793 Views
Nov 22, 2021 5:08 pm
- 64731 Views
Oct 10, 2021 9:14 am
- 56678 Views
Oct 29, 2021 9:24 am
Users browsing this forum: Google [Bot] and 3 guests
