Inner pad question + weird foam shapes
I'm in a full resto of a 86 v-king. Everything is going well, I'll spare you the details about the demo since you've seeing plenty off already.
floor is out, complete core is out, transom is out. Now, for the inner section of the pad, do I need to cut the top off and check the inner section of the 8 inches ?
I have pictures but the site won't let me post them
Go fast with class
Re: Inner pad question + weird foam shapes
You got to have at least 3 post before you can post pics. If you are talking about the pad core yes remove and I would replace all the core.
[ Post made via iPhone ]![Image](http://www.hydrostreamforums.com/images/mobile/iPhone.png)
WITHING THE SAME POST WILL COUNT ?!
I mean, I got the 'box' (old stringer over pad) out. I took the core out, grinded flush. but the is obviously an inner section (the pad) that is covered with glass right now. Most of the installations I say here, people put their new stringers over that top coat of glass all the way to the transom (knee braces) But I have never seeing a picture with that top coat off. What is the pad filled with ? green foam again ?
![Smile :)](./images/smilies/icon_e_smile.gif)
Go fast with class
My dads Vking just had stringers and core in the pad
It will be re-cored and done properly (vacuum bagged etc) just want to get all the rot out. But I had never seen any pictures with that layer off. So maybe it was just they way it was made.
Also, what is the purpose of the part under the dash where we rest our feets ? Is is a support od some kind, a water barrier or just a foot rest ?
Go fast with class
That is what they call the air box, it's for support. After you remove it and go back with everything you can just add bulkheads
THIS IS THE PART. Do I cut the top of that to check inside the pad ?
![Image](http://img.photobucket.com/albums/v155/the_kid016/image_zpsbdde177b.jpg)
this is under the front dash.
![Image](http://img.photobucket.com/albums/v155/the_kid016/image_zpsceffbb18.jpg)
under the floor, over the core I found these weird shaped foams. Probably old foamcore, but my concern is more, why and how did they get weird like that ?
![Image](http://img.photobucket.com/albums/v155/the_kid016/image_zps307f1ca6.jpg)
![Image](http://img.photobucket.com/albums/v155/the_kid016/image_zps5a456177.jpg)
Go fast with class
You had a fiberglas box stringer correct? And yes that layer in the middle has to come up cause there is core underneath the glass
That foam looks like it was added later in life, possibly weak spots in the floor and previous owner tried to strengthen it by filling with the foam
varmint1 wrote:You had a fiberglas box stringer correct?
YUP. TIME TO DIG THE PAD BOX ! THANKS
Go fast with class
- 8767 Views
Jan 10, 2023 8:43 pm
- 6979 Views
Jan 30, 2023 12:07 pm
- 10461 Views
Feb 16, 2023 11:49 pm
- 9279 Views
- Last post by dehydrated
Feb 18, 2023 11:19 am
- 9771 Views
Mar 11, 2023 10:57 am
