Viper rebuild
- Been thanked: 12 times
Re: Viper rebuild
Looks like my Viper will be finishing it's restoration in Southern Michigan. Got it loaded on the trailer and took it for a
"rough" ride this afternoon to see how things will travel. It's about a 4 hour trip of mostly highway. When you look at the pics, understand things are just roughed in till I get there. I'm building a new shop and progress will slow down for a bit on the Viper.
- DSCF4778 (Copy).JPG (180.63 KiB) Viewed 2573 times
- DSCF4781 (Copy).JPG (158.79 KiB) Viewed 2573 times
Re: Viper rebuild
After bouncing the rig down some crappy roads, checked the transom to see if there was any signs of stress. Pretty sure with the 1/4" t-6061 aluminum plate on the back, the knees built into the transom along with the added gussets screwed and glassed into the splashwell, transom fatigue and/or sheer won't be an issue.
- DSCF4784 (Copy).JPG (136.29 KiB) Viewed 2573 times
- DSCF4785 (Copy).JPG (149.75 KiB) Viewed 2573 times
Re: Viper rebuild
That Viper looks evil, hope everything works out fine for you
Re: Viper rebuild
I have not been able to work on the Viper since August. I got married in September and moved to southern Michigan. Since I moved from my shop in Indy, had to build a new shop. The new shop is built and all the electric has been run. Working on insulation and heat now and will need to get the new building "tooled" up. Hope to be back at it sometime soon.
Thanks for the inquire.
Hydromirk wrote:Have you Ben working on the viper,how's the build going
Re: Viper rebuild
The Viper is patiently waiting for some more attention! Snow is flying outside and it hasn't gotten over 20 degrees in quite awhile. With no shop heat yet...motivation levels are pretty low.
- DSCF4847 (Copy).JPG (108.47 KiB) Viewed 2487 times
Re: Viper rebuild
Merry Christmas and an enjoyable New Year to my fellow "streamers"! Thanks for your patience while following this thread. Hope to get on the water sometime in 2014.
Re: Viper rebuild
WTF!!!!
hellooooooo..........is anybody here?????
- 2939 Views
Nov 24, 2013 8:11 pm
- 3816 Views
- Last post by aaron78viper
Nov 26, 2013 11:15 am
- 6510 Views
- Last post by p man
Jun 29, 2016 4:01 pm
- 6712 Views
Dec 04, 2013 8:45 am
- 18Replies
- 18720 Views
Jan 19, 2014 7:53 am
