1973 ventura 1
Been thanked: 9 times
Re: 1973 ventura 1
Post: # 18854Post transomstand »
gatorstone wrote:where can i get the prop and how do i know the rating of this engine?do you know a i6 guru?how many of the ventura 1's are left i can't find any for sale
Not a lot of Ventura I's around, but they do turn up. Hydrostream was pretty much just an upstart company in those days, so I'm sure the overall production numbers were low, plus many were raced and probably just got plain used up, and went to the scrap yard. Venturas in general were lower volume than the other models. At the dealer I worked for, mine was the only one ever sold, everybody wanted them pointy ones :dunno:
If your motor is newer than 1982, it will be propshaft rated, and similar in performance to the 1500 from the mid seventies, which was flywheel rated.
Re: 1973 ventura 1
Post: # 18855Post transomstand »
varmint1 wrote:Pete why won't a 115 push a varmint that fast
Isn't the Varmint a good bit heavier?
varmint1
Re: 1973 ventura 1
Post: # 18856Post varmint1 »
What is the hull weight of the Ventura 1, also the 115 we had was a red band so that would explain a lot.
Re: 1973 ventura 1
Post: # 18857Post transomstand »
varmint1 wrote:What is the hull weight of the Ventura 1, also the 115 we had was a red band so that would explain a lot.
Ventura I was a little under 600 lbs, Varmint was probably closer to 750-800, and yea, the red stripe 115 would be rated 90 hp today.
Anyway, Venturas are just better :naughty:
Re: 1973 ventura 1
Post: # 18880Post transomstand »
gatorstone
Re: 1973 ventura 1
Post: # 19624Post gatorstone »
transom stand i have stolen a 1977 150!!!!!!!!!!!!!!!!!!140 across the board!now what prop do you suggest and still no jack plate?i have my boat split putting new core and transom in all composite.i could make the transom any height it had to be if no jack plate.my transom will extend the full width of the boat and have a monster knee glassed in the center maybe two more in the ears.how fast is this gonna get me i am stoked!
Re: 1973 ventura 1
Post: # 19626Post transomstand »
26 small ear Chopper should do it, you'll want an overall transom height of about 25".
gatorstone
Re: 1973 ventura 1
Post: # 19627Post gatorstone »
whats the set up on your boat and how fast is it?do you think i can get 80 out of my set up and is my boat stable at that speed?
Re: 1973 ventura 1
Post: # 19633Post transomstand »
gatorstone wrote:whats the set up on your boat and how fast is it?do you think i can get 80 out of my set up and is my boat stable at that speed?
The only thing that your boat should have like mine is dual steering, kill switch, and maybe solid motor mounts. Beyond that, the two boats will have nothing in common for setup because the boat's needs are completely different. Do not make the mistake of trying to set it up like a V-6, because it will be a dog. With the larger motor, your goal is to hold the boat down, especially over 90 mph. With the inline, your trying to get the boat up, and get it to fly as much as possible. You want to stick the nose in the air with a lot of trim, if you did that at the higher speeds produced by the V-6, you would only be a crash dummy for life jacket tests.
The inlines make the boat underpowered by todays standards, however, they are a BLAST to drive and are a far more "pure" driving experience. I think a lot of the young guys really missed out on that experience that us old guys had. And yes, 80 is possible but not likely because it would be an all out effort in both work and expense to get there.
Re: 1973 ventura 1
Post: # 19634Post transomstand »
I love these shots of Joe Sauer's boat. This is how we flew them in the old days. Compare that with the shot in my sig pic and you'll see how much flatter we run them now with the bigger motors.
