Vking windshield mounting
Re: Vking windshield mounting
would post oic but all i got is iphone no computer to downsize maybe hippie or ydoc probally got a pic if it or go to my profile http://www.hydrostreamforums.com/viewtopic.php?f=13&t=2313 this has pics of windshield on my comp vking
weather warming here in ohio maybe slide over to storage garage & get a few shots. gary
- hydrostream.jpg (884.39 KiB) Viewed 7559 times
Do you run it without a top rail? If so, how fast?265mercman wrote:would post oic but all i got is iphone no computer to downsize maybe hippie or ydoc probally got a pic if it or go to my profile http://www.hydrostreamforums.com/viewtopic.php?f=13&t=2313 this has pics of windshield on my comp vking
Stephens boat is slow!! 45 maybe 50 mph
BQUICK wrote: Do you run it without a top rail? If so, how fast?
got top rail on prep-etch primered sprayed silver base flake clear coat on rail / windshield is the gell coat black .dont know about the test havent has it out sense instaled. gary
lmao ydoc yea 45-50 at idle lmao iam running gps 94 rite now no top rail and building a new motir as we speak hopefully turn 108 gps and it still want need a top rail
What bolts did y’all use for the front bottom mounts?
I haven't bolted mine on yet, but i took some measurements.
The acrylic windscreen is 3/16" thick.
The lower trim rail is 1/8" thick.
I would venture a guess that the fiberglass thickness of the deck is roughly 3/16" thick. (I added some layers of 1.5oz CSM and 1708 glass to the underside. Let's be generous and say 1/4" thick max)
That puts the total thickness of all 3 at 9/16". Add in extra bolt length for the nut.
You could probably use 1" long machine screws.
The holes drilled into my windshield and lower trim are 1/4" diameter.
You should be looking at using #10 (3/16) or #12 (7/32) machine screws.
#8's (5/32) might allow for a little more play when trying to line up the holes if your deck is also drilled.
- 6423 Views
- Last post by Searad1
Jul 10, 2015 1:41 am
- 3649 Views
Jul 12, 2015 7:45 pm
- 3437 Views
Aug 08, 2015 4:52 pm
- 7377 Views
- Last post by digitish
Jul 20, 2015 6:23 am
- 7051 Views
- Last post by Alexjoz
Aug 04, 2015 4:08 pm
Users browsing this forum: No registered users and 54 guests
