prop for voodoo
prop for voodoo
had 1979 70 hp mercury with a 18 inch chopper on my voodoo. I am puttin a 1974 70 hp johnson stinger on it the shaft is 13 spline like the merc put the shaft is longer and stepped at the back. Do I need a new prop or do I get it rehubed. do I need a bigger prop because of the size of the gearcase.
thanks I need all the help I can get.
Re: prop for voodoo
You should be able to have the prop rehubbed for the stinger. Run the prop you have, see what you think of it. See where your rpm and top speed are at, how it handles, how it carries the boat, then make prop changes from there.
[ Post made via iPhone ]![Image](http://www.hydrostreamforums.com/images/mobile/iPhone.png)
Re: prop for voodoo
Good advise above.
You may be able to fit your prop to the OMC with washers, etc., for testing. (maybe not)
My motor is a different size, but I obtained a custom thrust washer that allows me to run OMC props on the Merc.
Re: prop for voodoo
You have a very good source of info in Suds, one of the fastest v-bottoms in canada. He's a busy guy, but great to talk to if you get a chance. Pm me if you like....
Re: prop for voodoo
I would like to talk to the guy. I know there are a few guys that run on long lake. might have seen his boat. what are you running on your voodoo motor size and prop. thanks
Re: prop for voodoo
My VooDoo has a 200 efi merc on it.... It isn't a VooDoo lol... I have a 16' Vision...
Re: prop for voodoo
I am 59 and my eyes dont see to good without reading glasses .was going by lettering on the boat. from a distant it looked like voodoo knew it said canadian edetion on the side. lol. dont see to many visions.
Re: prop for voodoo
Yeah my Vision is a bit of an oddball. This is my fourth season with it, and I'm still wrestling with setup. I'm almost there!! Shoot me a personal message, I'll see what I can help you with...
- 16Replies
- 24052 Views
- Last post by rhino875
Oct 05, 2015 10:13 am
- 11566 Views
May 02, 2014 9:47 am
- 6178 Views
- Last post by zizziz
Apr 22, 2014 10:37 am
- 11071 Views
Apr 22, 2014 10:38 am
- 10187 Views
Apr 14, 2014 5:38 pm
Users browsing this forum: Google [Bot] and 0 guests
