Vulture setup
Re: Vulture setup
I don't think you will see a dramatic increase in speed being it's not too far off now. But with a combination of things you will hit 80.
What rpm's are you seeing with your props?
A cheap hp increase is in cutting your heads to 35cc and bumping timing up to 25 degrees, you will need to run fresh 91 octane gas.
Re: Vulture setup
Right now with the 24 Trophy I am turning 6800-6900. The results have varied some with the other props. The 26 re3 was turning 6500 or so. 6800 with one Yamaha drag in a 24" 7200 with another. But mostly I just lose topend with all the other props I have tried. I gain lots of bottom end but I am not drag racing, just looking for that elusive larger number. Thanks, Dwayne.
Re: Vulture setup
I got my 6" set back plates installed between the transom and hydraulic plate. Going to stop tomorrow on the way to the river and level boat and propshaft so I can adjust my height. Hopefully it help the boat free up and run a little better. I should have something to post in a day or two on the outcome of the longer offset. Dwayne.
Re: Vulture setup
Can't wait to hear how it goes.
Re: Vulture setup
Well, I made it to the river today and did a little testing. The extensions didn't increase my speed yet, but did make the boat drive better. Now to more or less start over with props and setup.
Re: Vulture setup
Bumping this up. What did you end up doing for setup and prop?
Re: Vulture setup
Hey everyone, figure ill add to this thread instead of starting a new one, I just sold my viper this past weekend and picked up a Vulture (I'd like to see my 40's). Took the boat out and it drives like a dream compared to "the death trap" as my friends liked to call it. The boat has a 77' 200 johnson on it right now and plan to keep it for a few years and build up a nice 2.5 for it. In the meantime I'd like to get everything I can out of what I have. I would like to get the motor moved back before I start messing with height and prop combos but not sure where to start. I have read everything from 6" to 12+"' for these boats. Just looking for a place to start. Any advice would be greatly appreciated. Thanks.
- 7363 Views
- Last post by Bpr427
Jan 22, 2015 9:16 pm
- 6219 Views
- Last post by fla.viper
Jan 11, 2015 10:27 am
- 3667 Views
Jun 18, 2015 3:06 pm
87 Valero- How dangerous to run with rotten core?
Last post by orig-owner87valero « Jan 14, 2015 12:10 pm - 10Replies
- 10096 Views
- Last post by rossi
May 07, 2015 7:52 pm
- 3277 Views
Jan 17, 2015 8:18 pm
