Trying to set up VKING Yt it's a 2003
Need help I have 6 inch jackplate 15 inch mid Bob's lwp 1/4 below running a 245 HP carburetor motor only running around ,84 mph I was told I need 10 inch jackplate
- Been thanked: 80 times
Re: Trying to set up VKING Yt it's a 2003
10 inch plate is way to much for a vking and with that 15" mid you could probably get away with a 4" plate.
If it was a vulture or a Vegas I could see a 10" plate for sure but way overkill for a vking.
Also, start with the prop shaft even with the pad seeing that you have a lwp and adjust from there. I know a few guys that end up an inch above the pad.
I have been 1/2 above no lift almost ride nose down running a 26 chopper I have trying a few different props now
Thanks for the info I will try anything at this point lol
You have a picture of the boat and set up? Where is the battery, gas tank, etc...
No pictures of set up I have lower unit off getting work done I have pics
Where is your battery and fuel tank in the boat?
Maybe you just need to trim it up more.
- 45862 Views
- Last post by Calhydro
Sep 15, 2018 6:58 pm
- 135750 Views
- 97257 Views
- 117873 Views
- 99530 Views
