I have a 2003 200 efi 3.0 that has been been having a issue of keeping the reservoir tank on the engine full. I topped of the 2.5 gallon tank on the boat checked and tightened all the caps and any connection and let the motor in idle fill the on engine oil tank to the top and tightened the cap down.
I thought the problem was solved but once it drew the reservoir tank down enough -r the warning beeps.
I re-checked all the simple issues caps and connection but this time i opened the line that fills the engine tank to see if there was a flow of oil and there was and the rate of oil was right at 1 ounce a minute at idle ( 6-800) rpm.
Reconnected the oil to fill the reservoir and the rate of oil flowing into reservoir is not the same rate as where i measured from...i know there would be a draw of oil to the motor but the flow to the tank does not seem right. The only other thing that is left to check is there is a in-line filter or maybe a check valve that close to the reservoir . I cannot remember if this was part of the package when i replaced the tank a few years back.
Is this something that would restrict flow if its a check valve or is it a filter? The filter in the big reservoir tank was perfectly clean.
If this valve is not the culprit what is my next step?
200 efi oil flow issue
Re: 200 efi oil flow issue
Some things you should check are mentioned in this:
https://www.thehulltruth.com/boating-forum/108514-mercury-using-way-too-much-oil.html
- 6384 Views
Jan 10, 2023 8:43 pm
- 5137 Views
Jan 30, 2023 12:07 pm
- 7631 Views
Feb 16, 2023 11:49 pm
- 6071 Views
- Last post by dehydrated
Feb 18, 2023 11:19 am
- 6526 Views
Mar 11, 2023 10:57 am
Users browsing this forum: No registered users and 58 guests
