1980 Viper Rebirth
Re: 1980 Viper Rebirth
I think Drew is holding back on the Venom. July 1st weekend there was a run up and down the lake....on their way down he was in last place being beaten by a Seadoo.
I have video proof on my phone. Ask Hippie, I showed him.
I have videos shot from that boat with the previous owner driving. It's been over 100mph, and feels effortless doing it. Drew may need more seat time to get comfortable in it, but the potential is there!
Here's an older one
Friday Sept 20th, 2019:
Apologies for the delay. Busy weekends happened.
After I had finished grinding the deck, I laid down overlapping strips of 1.5oz CSM over the entire deck's underside. except for the dash. I left that bare for when I clamped in the new plywood.
Next, using my old dash as a rough template, I cut a new one out of 3/4" marine plywood, and trimmed it down accordingly to fit.
I "primed" the dash with resin and doubled the catalyst (4%), and let that sit. In the meantime, I whipped up a batch of CoreBond, and put in "wedges" in the notches where the windshield frame screws in to.
Back to the dash, I laid on 2 layers of 1.5oz CSM, and clamped her into place.
Was busy all Saturday, so this is what I got done today:
Sunday Sept 22nd, 2019:
I cut out strips of 1/4" exterior mahogany plywood for the sides. I'll be laying on 2 layers of them for a 1/2" combined thickness. This will be replacing the 1/4" (or 3/8") strip of original plywood.
Here they are at their full 8 foot length, but i decided to trim off the forward foot as I plan on adding extended gussets on both sides of the dash.
Soaked them in resin, and clamped into place.
Starboard side...
I didn't take pictures for this really, but I cut a strip of 3/4" marine ply for the splashwell "cross-brace" (as I call it...), and clamped that in.
Added in 2 wedges, CoreBonded and resined into place.
Port side:
After a few hours, I removed most of the clamps, mixed up some more resin, and re-clamped the sections to get the proper "bend" near the splashwell.
Also slathered resin on the outer side of the plywood panels. I plan on glassing these over tomorrow, so I'll still be able to maintain a chemical bond.
Starboard side...
Port side:
Looking good buddy!!
Looks great! Keep up the good work!
Saturday Sept 28th, 2019:
Unfortunately, last week kicked my butt with work. Not getting home until 630-7pm every day didn't leave any time to work on the boat.
With the weather turning, I didn't want to leave the deck protected by just a crappy tarp.
Time to rebuild my hoisting frame and get her inside the shelter.
Hopefully I can knock off a few things this coming week. First, cleaning up all the crap and re-organizing my tools. Second, getting the side and centre braces installed on the dash and glassed in.
Once that's done, I can move the deck back outside onto its sawhorses and flip it right-side-up and leave it until I get the hull structure finished.
My 5-year wedding anniversary was Friday, and I worked, and wife worked today, but we're both off Sunday, so she wants a "date" day. Which means boat gets neglected.
- Been thanked: 12 times
Amazing work Adam! Awesome documentation of the process.
Wednesday Oct 2nd, 2019:
I added 2 more pieces of 3/4" marine plywood to the splashwell bulkhead. Simply forward thinking about how I'll have the rear bench seat secured in place. I'm leaning towards a set of draw latches at the top back of the seat, this way I can mount hinges at the front bottom of the bench, and the whole bench will fold forward allowing access under the splashwell.
(The orange string is just for marking the centre-line of the deck.)
Next I worked on a set of gussets for the dash. I used styrofoam to create a template, then cut 3/4" plywood pieces to match.
I primed the gussets with resin, letting them sit for about 45 minutes.
Then mixed up some CoreBond, catalyzed, and put it in a Ziploc bag. (thanks Ron! @alaskastreamin )
Squeezed it out like icing, set the gussets in place, and then weighted down.
They are 9 inches apart, which leaves plenty of room for a hydraulic steering helm (a SeaStar Pro helm is 4.5" diameter.)
Weather up here is starting to cool off....I'm trying to get as much done as I can before temperatures start dropping below 65 on a regular basis.
Tuesday October 8th, 2019:
Had the day off today. Sunny and almost 70 degrees. Time to work on the dash edge gussets.
For the starboard side, I templated out a piece of 1/4" exterior mahogany plywood, then cut a second piece to match.
Laid the inner piece down, brushed on some resin, put on a layer of CSM, then the outer piece. Weighted down with some interlocking bricks and a 40 pound cinder block.
Let it cure up for about an hour and half, then templated out pieces for the port side.
I sandwiched those 2 pieces, then went to work setting the starboard gusset in place.
CoreBonded the deck-side edge, then clamped into place.
After another hour and half, removed the starboard clamps, then set the port gusset into place.
This is all for today.
Next is to sand all the excess CoreBond off, then start glassing over it all.
- 2228 Views
Aug 15, 2011 7:06 pm
- 3679 Views
- Last post by Seth80
Aug 16, 2011 8:32 am
- 21Replies
- 6772 Views
- Last post by hydrostream280
Dec 16, 2011 1:13 am
- 2361 Views
Aug 16, 2011 9:46 am
- 2490 Views
- Last post by joeboat
Aug 16, 2011 8:55 pm
Users browsing this forum: No registered users and 97 guests
