About what volume of gel coat will I need to re gel the hull and the deck of a valaro?
Thx
Amount of gel coat to cover hull and deck of a valaro or v -king
- Has thanked: 350 times
Re: Amount of gel coat to cover hull and deck of a valaro or v -king
I can't help you there but in sure someone like Tony (tnelson) will chime in before too long. He just re-gelled his Viking, top and bottom. It looks stunning! He has pictures here in the resto section.
Depends on what you plan to do. I sprayed flake on my boat so I needed three total layers of gel to get it right(Base color, flake/clear, clear). If you're doing a solid color on the whole boat you could do it with one coat. Each coat took about 6-7 quarts of gel for each the hull and deck. So for a single color boat I would grab a 5 gallon pail and you should be covered. If you're doing flake its a whole new game. But figure 6-7 quarts for each layer of gel on a 18' stream. I figure I laid it down around 26-32mils, which is a bit on the heavy side.
- 138604 Views
- 145886 Views
- 90011 Views
May 22, 2022 8:22 am
- 55951 Views
- Last post by blowitup
May 28, 2022 10:58 pm
- 46940 Views
- Last post by Mikem
Jun 03, 2022 7:47 am
