New project- 89 Voyager
Re: New project- 89 Voyager
Those cricuts are handy little machines. A friend of mine owns one and I've had a few decals made up.
Just found this thread and am I glad I did. I also bought an '89 Voyager last summer. Thanks for sharing the rebuild process. Very educational. Cheers and great work!
Congratulations on your Voyager.
Please start a thread and throw in some pictures.
I started a how to upholstery thread in the interior forum.
Update:
Got the interior all stitched up ( that post is in the interior forum)
I got my block back from the machine shop, bored all six to .015 over. Bought new pistons and a gasket set from ProMarine. Sent injectors off to be checked and cleaned.
It had low compression on 4&6. The injectors weren’t bad so still curious why it scored .
Hung power head, got my 1/2” pipe tap and drill bit so I could finish the nose cone plumbing. I painted the lower with some left over Dodge silver and clear coat .
Getting real close now.
My carpet is at a Phil’s place. He’s 3 hours away so I’ll get it when it’s holding me up.
Still need to assemble seat sliders & swivels and mount seats so I can position the foot throttle. Then run the engine.
- 17A4BBB5-FE14-4219-B550-EB92441D182A.jpeg (91.78 KiB) Viewed 13745 times
- CD44113D-39ED-4996-821D-A0B036FCA28D.jpeg (77.77 KiB) Viewed 13745 times
- F3D2AA6A-CC53-4F44-A3A3-92F8CE6A5DBF.jpeg (95.15 KiB) Viewed 13745 times
- C281E208-2A1A-410A-A31E-C468ABC7AC93.jpeg (109.04 KiB) Viewed 13745 times
- 7AF89E2F-0DEE-4E66-96C0-3FCC4568BBBA.jpeg (129.15 KiB) Viewed 13745 times
- EF0F4331-F4D4-424F-82F8-6BD716541A69.jpeg (115.53 KiB) Viewed 13745 times
- 3267B5A9-B77C-4F9E-8966-C3B1DE1BEF70.jpeg (129.4 KiB) Viewed 13745 times
- 5917FBC0-B42B-4FF0-8988-6844103F14C7.jpeg (111.84 KiB) Viewed 13745 times
Did you do the nose cone job yourself?
Yes I did.
Go back to page three. Second post down. Lol!!
Got the lower unit back on. A neat trick I do to control the alignment is to use a ratchet strap to hold the lower. If the driveline splines don’t align just add a little pressure and now your free to move flywheel. Same for shift shaft.
I installed my homemade drag plate with “elevator bolts” .
I really like these fasteners. They are found at true value / ACE hardware stores in the nut& bolt isle. They are in the stacked specialty boxes. They have a large flat head so no need for a washer.
The carrier nut hadn’t been torqued yet as my wrench goes to 180# and the nut is 210#.
With the lower mounted, I called a friend with a wrench that would work.
- 964C4FE6-1159-40A4-9D05-ED5206E99D6B.jpeg (104.2 KiB) Viewed 13741 times
- 7A07588E-762D-4D02-9AA9-6F575C6FD39D.jpeg (67.17 KiB) Viewed 13741 times
- 14E56FED-50D2-4207-96B2-DE84D63AE9D3.jpeg (72.69 KiB) Viewed 13741 times
Well the first hour on the water was great. Then a little rattle so I shut her down. Pulled plugs. #6 looked dry and powdery.
Towed to launch ramp to be safe. Pulled head and #6 detonated!!
Now to figure out why. This motor has an ignition ECU and a fuel ECU. A crank sensor& throttle position sensor tell the computer where to set timing. No trigger on these.
I indexed the flywheel for all 6 cylinders marking 0* and 25*
Timing is supposed to be checked with motor running at full throttle. Well how the hell am I gonna do that? Maybe tied down on trailer at ramp-.....at night so I can see the timing light???? Most likely...
I tried it with the starter and they were all between the 0 & 25 marks.
Powerhead is broke down and at the machine shop getting a .005 hone. It was at .015 and some light scoring will come out with the hone. I’ll get a .020 piston and do some more testing..
- A8AAF04A-9C09-43FA-AE45-B93CEAF5B40C.jpeg (88.84 KiB) Viewed 13728 times
- B6788797-8D80-4BBD-875E-DC8B4796123C.jpeg (102.43 KiB) Viewed 13728 times
- 3D766B98-A80B-4BF9-B660-FD709B393B5F.jpeg (95.44 KiB) Viewed 13728 times
- C36B518D-9AAF-4DF0-9B6B-C9345699E784.jpeg (76.82 KiB) Viewed 13728 times
- 5A2314AA-7FF7-4C22-9F9D-C44140B44C37.jpeg (120.17 KiB) Viewed 13728 times
- D2145C91-60AC-4632-B8F0-9A09CF5D6DDC.jpeg (151.28 KiB) Viewed 13728 times
- 4797 Views
- Last post by shellyisland
Oct 12, 2009 5:10 pm
- 16Replies
- 14529 Views
Oct 22, 2009 9:47 pm
- 6384 Views
Oct 14, 2009 9:32 pm
- 10964 Views
Oct 16, 2009 9:27 am
- 6343 Views
Oct 15, 2009 6:33 pm
Users browsing this forum: Majestic-12 [Bot] and 2 guests
