Building interior from scratch
Got my 1/4” staples so I could assemble the side panels.
Turned out great.
Turned out great.
- DF59541F-3958-4CA1-B1BE-80C22127D0F7.jpeg (69.91 KiB) Viewed 21137 times
- C2E61BC4-4AA4-4D70-A023-A83290E45017.jpeg (103.99 KiB) Viewed 21137 times
- 64A09D58-E809-4712-9DA2-FA3A3FBB2779.jpeg (104.06 KiB) Viewed 21137 times
Puttering away still.
Working on the rear seat bottom. Getting the stitch lines to align is time consuming.
I need to get some “pull fabric “ before I can install the cover.
This is a non stretch fabric that pulls the bolster down to the base.
I loosely slipped the cover on and am happy at the initial fit.
The steamer is coming down from Alaska so the wrinkle in the armrest should come out. ( in case you noticed it).
- 6051A4B7-73A0-4726-AFF5-1E1CA80E2783.jpeg (81.54 KiB) Viewed 21132 times
Wow! Looking great Ron! I should send you a few seats. lol
Dang Ron. You're really starting to tempt me into doing mine now. I'm starting to loose confidence that the shop I initially talked to will complete mine in time.
Haa! I wish I could help everyone out. Truly!!
It’s very rewarding but I’m slow.
Got the rear seat bottom fitted.
Going to finish the back side of the backrest next.
Finish stapling, trim edge, put on white screen material and “hide-em” to cover staples.
- 87DA1250-A533-452F-BDA2-BE70E4C8156E.jpeg (49.77 KiB) Viewed 21124 times
- 567784FD-898A-431C-979F-31339DF2B095.jpeg (91.11 KiB) Viewed 21124 times
- 22458443-489B-4321-A327-73146C67D972.jpeg (78.25 KiB) Viewed 21124 times
- D54C2C4F-4336-4B96-B6BD-9B9D7BBBA248.jpeg (98.28 KiB) Viewed 21124 times
That looks great Ron! Im with Tony. I might have to try my hand at doing my own.
Thanks guys! I really appreciate it.
Here’s the back trimmed out. Really cleans up the back when the rear hatch is open.
- F1979322-E40D-48EE-B589-C644442D9F3D.jpeg (87.12 KiB) Viewed 21122 times
- 7306FD5C-F354-4CDA-AB33-FACE4D92EA83.jpeg (95.65 KiB) Viewed 21122 times
- 444E0C24-4365-432B-8D95-51743E7A0328.jpeg (90.99 KiB) Viewed 21122 times
I spent the day making windlace to run the perimeter of the side panels. And stitching up the rear hatch area.
I can’t staple it till I get the rear side panels on then rear seat set in. THEN I can align the stitching.
I didn’t think about the bulk when folding the edges.
When I drilled the panels for the clips, I had the bare wood against the boat. Now with the extra material. ( bow side panels), the push pins won't align . I’m going to cut them off and put in rivet nuts with studs. Then I can slot the holes in the fiberglass and use nuts.
- E2AA2EED-7E1E-4D4F-B167-4EC6885F6DD1.jpeg (65.89 KiB) Viewed 21119 times
- 46BB2A83-61D2-4F10-91A1-A2E7F5BA2ACC.jpeg (69.34 KiB) Viewed 21119 times
- 764ACB64-7DDB-4A4C-9B16-CC97F1EB3D2C.jpeg (82.79 KiB) Viewed 21119 times
- D269324C-6783-42DA-A2D1-B8ABB57FEABE.jpeg (73.2 KiB) Viewed 21119 times
- DF386AE2-A01F-48A4-8C4F-687232227445.jpeg (97.85 KiB) Viewed 21119 times
- 4C0D88A0-D994-4B91-B29B-104E9ABF72DB.jpeg (80.06 KiB) Viewed 21119 times
- 5CB3E12F-2D10-4F83-AC2B-DBCB45671C7B.jpeg (71.26 KiB) Viewed 21119 times
- A87419EF-EF94-4EC5-90F9-EBB0BCD91B08.jpeg (58.16 KiB) Viewed 21119 times
This is 8 hours work.
Front buckets-
Building center section first working outward.
Front buckets-
- EE0DE402-00D7-420E-9A9F-A2004EB287D9.jpeg (76.15 KiB) Viewed 21115 times
- 6A1FF398-8236-439A-8E81-474426642647.jpeg (82.98 KiB) Viewed 21115 times
- E19A7A78-0482-459C-8144-CAD8DBAFD249.jpeg (63.05 KiB) Viewed 21115 times
- DC84273D-E720-4124-B8ED-162DB2A3A91F.jpeg (63.47 KiB) Viewed 21115 times
- F7087391-BAE6-40D7-A02E-2732C4F633A7.jpeg (72.44 KiB) Viewed 21115 times
- 35E33B1A-5512-4B9A-8048-A754BF19770F.jpeg (67.56 KiB) Viewed 21115 times
- 0A797DDB-460C-4FD1-9CB3-22A82CE4E375.jpeg (63.14 KiB) Viewed 21115 times
- 1DE7C619-F717-42AB-91F0-96A944B6FB11.jpeg (67.18 KiB) Viewed 21115 times
- BE68BFAC-B41C-4B57-AFED-8154C7402E13.jpeg (84.88 KiB) Viewed 21115 times
- FD176336-2004-44D4-B97D-070E78C80801.jpeg (83.85 KiB) Viewed 21115 times
Got the covers on the front seat shells. Overall not a bad fit.
I’ll get the steamer fired up and see if I can work out some of the wrinkles.
- 1717E365-3055-498C-9060-5A5A7B9973F9.jpeg (79.26 KiB) Viewed 21111 times
- 8571 Views
- Last post by wildfire78
Dec 27, 2009 10:44 am
- 4104 Views
- Last post by charleskiller
Dec 08, 2009 7:38 am
- 4889 Views
- Last post by skurz
Mar 15, 2011 9:28 pm
- 18Replies
- 9664 Views
Dec 11, 2009 7:16 pm
- 4175 Views
Dec 11, 2009 9:02 pm
Users browsing this forum: No registered users and 49 guests
