1978 Viking resto-mod
Re: 1978 Viking resto-mod
Ron, I'm about 2-3 weeks away from having everything completed. Then planning to drop it at the upholstery shop. We'll see how fast she can turn it around.
Thanks, Proprider!
Thanks, Proprider!
Well its done! (nearly) Upholstery shop is dropping the ball on getting seats back to me. So the original seats went back in so I can run it until they're ready to make the new ones.
Ron, I really should've listened to you and just bought a machine and done it myself. Then I could've said I did every last bit of work myself. Who knows, might still get to this point haha.
Fuel tank was installed and plumed, GPS was added with glue in transducer, motor has been test ran. A few minor water leaks to take care of on the motor but overall ran great!
It will go in the water the way it is now. Planning for Saturday May 29.
- IMG_7744.JPG (723.51 KiB) Viewed 10068 times
- IMG_7839.JPG (750.95 KiB) Viewed 10068 times
- IMG_7858.JPG (867.19 KiB) Viewed 10068 times
- IMG_7886.JPG (810.77 KiB) Viewed 10068 times
- IMG_7887.JPG (803.75 KiB) Viewed 10068 times
- IMG_7888.JPG (862.84 KiB) Viewed 10068 times
- IMG_7890.JPG (650.61 KiB) Viewed 10068 times
Looking good!!
What brand is your switch panel? Lol!!
I’m going to try and get out next weekend also.
I forgot to add in my post that I'm still waiting for the machine shop to run the CNC program for my actual panel. It is a piece of 1/8" aluminum that I had anodized blue and the words will be just touched off with a ball end mill. The current one is a piece of 1/4" plywood that was laser cut to the same program to test fit. I figured I would keep it there as a switch holder while building the wire harness. Looks like it will be there a bit longer haha.
Looks great! Better get video!!!
All 5 GoPros ready to go, about 15 batteries charged.
Ron, the switch plate came back just in time!
- IMG_7915.JPG (889.78 KiB) Viewed 10059 times
I cant wait to see some video!!!! At least post up some pics right away of it in the water.
Have a good day!! That panel looks awesome!!
I’m having my maiden voyage today also.
First weekend went pretty well. Was able to click 68 according to the GoPro GPS, the Garmin in the boat showed 69. Only hiccup was the studs that mount the lower worked themselves loose. The rear two fell out completely, one of them taking a nick out of the prop. I should be able to take care of that myself, its pretty small. The front two thankfully only can back out so far so the lower didn't fall off completely.
Everything else was great! Just going to take some time to learn how to balance on the pad.
- IMG_7925.JPG (714.67 KiB) Viewed 10048 times
- IMG_7932.JPG (402.3 KiB) Viewed 10048 times
That first outing is always a little nerve racking.
Hoping everything goes smoothly.
Glad you got home under your own power .
- 80375 Views
Feb 22, 2019 11:52 am
- 170891 Views
Dec 13, 2019 7:07 pm
- 69080 Views
Feb 24, 2019 10:11 am
- 87731 Views
- Last post by CleanV-King
Dec 29, 2020 11:32 pm
- 78627 Views
- Last post by dehydrated
Mar 08, 2019 11:15 am
Users browsing this forum: No registered users and 75 guests
