The gelcoat and some structural putty arrived.
Got the front stringers cut and the transom plywood.
- 7C75AB83-945C-436E-89E6-52B92AA2A96C.jpeg (144.71 KiB) Viewed 6947 times
- E5E4CD8A-3624-42E7-92DC-521081BC6C17.jpeg (145.36 KiB) Viewed 6947 times
You sure know how to make this look easy. LoL
The chop glass ( Mat) arrived and was torn into 4”, 6”, & 8” wide strips.
A neat trick is to clamp a straight edge at one end , slide the mat under and tear it like wax paper. It takes a bit to get the feel but it’s a quick way to get it done without a hard edge.
- 13F8B150-C974-466D-BD17-F2B7545FFA1C.jpeg (116.54 KiB) Viewed 6937 times
- 4146E91E-2F09-4833-9898-16EFF192DEA6.jpeg (123.71 KiB) Viewed 6937 times
The 5 gallons of resin arrived last night.
Had enough stitch mat to get the deck laid up this morning.
- FAD65E92-5BEA-4F35-A6C4-9E4C8F7963FE.jpeg (111.68 KiB) Viewed 6932 times
- 674198D8-044C-467C-87C7-213450AED1C8.jpeg (107.9 KiB) Viewed 6932 times
While waiting on the stitchmat to come in, I made a glove box. It fits behind the opening the old stereo was.
- C1804480-4A92-4448-836E-5C609196091D.jpeg (119.42 KiB) Viewed 6917 times
- BD186D24-C400-47D6-8D4F-6991FF47954D.jpeg (134.89 KiB) Viewed 6917 times
- 66AD0C95-FC06-4E48-ADF5-0971A08983A0.jpeg (144.15 KiB) Viewed 6917 times
- 9ADB0401-D95F-4B13-94E0-2C0B1546CBBA.jpeg (109.34 KiB) Viewed 6917 times
- 1922970D-DCF4-4857-8185-E9AD4CE16F87.jpeg (111.51 KiB) Viewed 6917 times
- 906D458A-FC70-4AA9-9334-4D8B07D55EC7.jpeg (105.62 KiB) Viewed 6917 times
- 8DADE943-5890-42B7-BF6D-1DBC48DB1D32.jpeg (126.13 KiB) Viewed 6917 times
Watching the tracking for the stitchmat. It arrived an our facility 5:15 am. Changed to “out for delivery” at 10:00am so I decided to get started.
I checked level again and used two floor jacks to hold the front stable.
Put three layers of mat down. Need it to kick before I add more layers. I’m making the ski locker floor from some left over 1/4” balsa. A mat and cloth were wet out over the under side.
Also trimmed the edges of the laminated transom .
Tomorrow will be a busy day.
- B521A466-6203-4D16-BCD6-168F1D62EC57.jpeg (129.72 KiB) Viewed 6908 times
- 97F73FD0-D92B-4368-A973-564AA17FAE0A.jpeg (157.6 KiB) Viewed 6908 times
- CDCFDC9A-353E-48D9-8D38-1B8DFE308D7B.jpeg (104.14 KiB) Viewed 6908 times
- 5B340CB4-EFB5-46DC-9C0F-5F58D30EB5A7.jpeg (130.14 KiB) Viewed 6908 times
Lots of resin was mixed today.
Got the stitchmat laid down, balsa bedded in center pad and tunnel tops.
Ski locker floor and forward bulkhead glassed in.
Realized 5 gallons of resin isn’t going to be enough. Got 3 more gallons ordered. Two should be enough but I don’t want to run short again..
- 69D6F28C-96B3-4850-8F60-4BED41704B02.jpeg (140.05 KiB) Viewed 6896 times
- 8B187B3E-A1E8-434B-B236-DBF210D3970C.jpeg (152.67 KiB) Viewed 6896 times
- 85D3664A-C988-4519-8315-36DEAA56697B.jpeg (168.04 KiB) Viewed 6896 times
Wow! This thing is coming along fast! Looking great Ron.
Thanks Kevin!!
Today will be the last productive day until the 24th. The resin order arrives on the 23rd. So they say……
Today I used the last 2 qts of my resin to glass in the bow stringers and replace the sponson tops I had to remove to get access to the hull.
I glued in the ski locker carpet, spread structural putty with a 1/2” wide X 1/4” deep trowel on the tunnel tops and bed in the floor.
There was just enough putty to put in the rear “drop” floor where the gas tank sits.
This next few days will be good to let the hull just sit in the jig and cure out.
- 3D66930B-4168-4A00-8521-673344711B75.jpeg (153.62 KiB) Viewed 6860 times
- F6426B32-DD4B-477B-BCD4-77E3C2726B41.jpeg (144.42 KiB) Viewed 6860 times
- 2E8380C1-0B79-4AE3-9EA4-2DEDD9B6DDB1.jpeg (148.52 KiB) Viewed 6860 times
- F742AC85-6EB5-4FB8-8B57-7E87D336FBC3.jpeg (131.73 KiB) Viewed 6860 times
- F9EAD4D3-D5CD-4E5F-B742-F9001375890B.jpeg (143.27 KiB) Viewed 6860 times
- CDB09BD9-6655-44D4-AC16-EF37946865DB.jpeg (147.5 KiB) Viewed 6860 times
- B62AC42A-677A-4EC7-B79B-327AA07D250C.jpeg (157.86 KiB) Viewed 6860 times
- 9504 Views
Sep 03, 2017 7:26 pm
- 7650 Views
Mar 09, 2018 7:06 pm
- 3337 Views
Aug 13, 2017 6:36 pm
- 12122 Views
- Last post by HST4ME
Nov 08, 2017 5:40 pm
- 4721 Views
- Last post by Valero 86
Aug 25, 2017 9:25 pm
Users browsing this forum: No registered users and 81 guests
