Just because I don’t have any resin doesn’t mean there’s nothing to do.
The ski locker hatch looked like it was made from pallet wood and sheet rock screws.
I went to Home Depot and got two 8’ sticks of Mahogany 1x4 and made a new one.
There was just enough scrap to make the glove box door.
A new tongue jack and wiring kit were put on the trailer.
I mixed up some pour foam and filled the forward sponson cavities.
- E8A36DB0-12B5-43A4-AFDE-A1991FDACCDF.jpeg (97.54 KiB) Viewed 9473 times
- 3AFA1BF0-69F7-4057-9151-4C7FA0726A37.jpeg (125.21 KiB) Viewed 9473 times
- E0C503D4-653F-4A98-9F0C-1467DBAB71B6.jpeg (112.59 KiB) Viewed 9473 times
- CF5963E2-3B96-4F13-9C82-423BFAAFDFF6.jpeg (98.26 KiB) Viewed 9473 times
Man, seeing stuff like this makes me wish I have a good heated shop. I would get so much more stuff done. LoL
I get it Kevin!!
When we bought this property in 07, it was an alfalfa field. We knew the importance of a large heated shop so it was the first building to get erected.
It has surely paid off. This is the only way I can get so much done.
I’m out here 8-10 hrs a day.
It’s 5* outside today and 65* inside.
I put the deck on so it would be easier to roll outside for the gelcoat grinding.
While waiting for the temperature to rise tomorrow, I decided to make a mold for the windscreen.
I’m running the sides a little further back as it seems to look better with the long lines in the deck shape.
Hot glued paneling and two coats of Johnson paste floor wax. The mounting flanges will be on the inside.
Also straightened the bow rail .
It was really outta wack!!!
- 11FBACCF-2774-425C-BC57-5F77026BD0B5.jpeg (64.43 KiB) Viewed 9459 times
- B6D91595-3C62-4554-B443-6DAACA8E7A71.jpeg (75.5 KiB) Viewed 9459 times
- 6F2E9BDC-E41B-486A-AA2E-097C1EF09F04.jpeg (68.31 KiB) Viewed 9459 times
- 98DB5E49-6931-4F81-B54B-6354AEA154CF.jpeg (127.54 KiB) Viewed 9459 times
- 35E0857C-6443-403D-881E-A3186666DBAC.jpeg (91.66 KiB) Viewed 9459 times
- 5851B3BE-AADD-4912-990E-BD2A70388440.jpeg (129.22 KiB) Viewed 9459 times
- DA98AF1E-2642-44CF-B7B0-E3DABBF8DC0F.jpeg (123.47 KiB) Viewed 9459 times
- 5E948662-EF55-4880-9EFF-4FFC11109BBE.jpeg (106.66 KiB) Viewed 9459 times
The steering wheel cover was coming apart so I stitched up a replacement.
Definitely not perfect but a fun little project nonetheless.
- EE2496EF-F954-4CFB-BED6-74FA3AE2C6CC.jpeg (100.83 KiB) Viewed 9448 times
- C792BB61-EF46-480B-8CD0-B8E6B7D188E6.jpeg (96.34 KiB) Viewed 9448 times
- 324DB408-577D-4256-9624-05DE2A9470B6.jpeg (120.73 KiB) Viewed 9448 times
- 544B0F72-600D-444D-A18A-B5EB9BD1765D.jpeg (121.4 KiB) Viewed 9448 times
So sorry I missed all this work so far. Lol not too many people in this world have the drive and dedication it takes to see a project like this come this far but knowing who you are and somewhat how your mind works nothing is impossible!!! I will try to get over soon to check it out Hopefully it will be done by then lol looking like it might be soon
No worries bud, there’s plenty left to watch.
Well, the three gallons arrived and I soon realized that I was going to be short AGAIN. ARGGGGG!!!
Got the rest of the bow stringers fully glassed in as well as the bulkheads, floor , seat bases, foot throttle pad, and floor side rails with the three gallons .
That leaves the transom , knee braces, and outside repairs needing resin.
- CD57E9B9-BBA9-41C4-9A0D-77A8A3D0D85E.jpeg (528.34 KiB) Viewed 9431 times
Today I put in the carpet. One piece 8-1/2’ x 9’.
I fit the gas tank and realized there’s no way you would get a bilge pump in the floor opening. There isn’t enough height.
I may drill a hole in front of the tank , thru the floor and put one there. There is bilge wiring already run and I have a bilge pump sitting in a box.
- B945F6B5-A521-453F-8B99-9C1455822D50.jpeg (151.54 KiB) Viewed 9431 times
- 7AE0A8F0-45E7-4189-8DAA-54D9F102EBA6.jpeg (148.83 KiB) Viewed 9431 times
- B973D8BD-4D5D-42D3-BC48-322FC4002059.jpeg (151.92 KiB) Viewed 9431 times
- E2B53829-F182-40C9-B142-CE6777B520C9.jpeg (139.25 KiB) Viewed 9431 times
- 50F0CD63-F2D6-4E65-B2F9-DC64EBB6196B.jpeg (142.67 KiB) Viewed 9431 times
- C4E4D7AC-DE74-4489-A3D3-FB83FE4FDCC6.jpeg (111.6 KiB) Viewed 9431 times
- C05BF421-F931-4020-A0C2-BA49E84E810B.jpeg (124.32 KiB) Viewed 9431 times
- AE9EDF54-7C8A-4B80-BB7D-5E8EE6E4D7D2.jpeg (119.96 KiB) Viewed 9431 times
- B7DFF00C-3B5F-4A62-93C6-F97E7CE781D6.jpeg (148.02 KiB) Viewed 9431 times
Today I put the deck back on and rolled outside to grind off the gelcoat that had spider cracking.
Luckily, most of it was just in the gel.
Bout 3 hrs work.
Bout 3 hrs work.
- 9556855D-04AE-4312-B388-DF05248B8552.jpeg (100.2 KiB) Viewed 9405 times
- 2DFA65AE-AFCC-48C9-B8A2-5B0CB4A87352.jpeg (105.33 KiB) Viewed 9405 times
I cant wait to see how this turns out! Looking great!
- 4628 Views
- Last post by ConFuseee
Jan 17, 2012 10:02 pm
- 3922 Views
- Last post by max94
Jan 14, 2012 11:14 pm
- 2797 Views
- Last post by whytey
Apr 22, 2012 11:10 am
June 7th-10th, NO name, NO host, NON event, Great Sacandaga
Last post by RussF « Jan 09, 2012 6:39 pm - 35Replies
- 23855 Views
- Last post by LSaupe
Jun 10, 2012 6:12 pm
- 3354 Views
Feb 13, 2012 12:24 pm
Users browsing this forum: No registered users and 77 guests
