Hello everyone, I recently purchased an 88 vision. I'm having issues with the boat proposing, it has a 150 merc on it which seems to sized right and not over kill. Once I hit over 45 km an hour it starts bouncing. I got it up to 81 km but it's bucking pretty hard on flat water. It has a 26 pitch chopper prop and a full tank and trimmed right down.
88 vision
Re: 88 vision
Welcome! Sweet looking boat. I personally don't have any experience with a Vision but a few guy here do. Hopefully they will chime in.
Re: 88 vision
I also have no experiences with the Vision so these comments are general. Boats often porpoise because there too much weight in the rear. This means that your center of gravity is too far back. Your engine is heavier than the boat was designed for, and the set back compounds the issue. With that power and that prop, your rig should obtain 112 km easily.
What I would try:
Prop-shaft 1 to 2 inches below pad.
23 or 24 inch 'ski' prop (this will carry you faster than your are going now). Go back to the chopper after issues are fixed.
Three- 20 lb. sand bags in front of feet. (Sand bags because they are easily moved.)
Make sure the boat is well balanced side to side also.
Best of luck! The fun is in the testing!
What I would try:
- 2890 Views
- Last post by Bayou Native
Sep 05, 2013 2:13 pm
- 7946 Views
- Last post by crankbearing
Aug 28, 2013 6:54 pm
- 9109 Views
- Last post by nosboss
Oct 18, 2013 8:50 pm
- 3522 Views
- Last post by xl428
Aug 27, 2013 2:11 pm
- 7452 Views
- Last post by steve3340
Aug 30, 2013 8:19 am
Users browsing this forum: No registered users and 88 guests
