My Varmint build
Re: My Varmint build
i'm looking for the emblems
My Varmint build
Hello Greg -
I found your thread linked to one started by Jerry Rut31 about his 85 Voyager purchase and rebuild. I am making a deal with him on that boat. It needs to be clear coated again. I am quickly finding out that it will be pretty expensive to pay to have this done. I think it is something I can do myself based on what I see in your thread. Can you give me any advice on the products you used and the process you went through? Any help will be greatly appreciated. Your boat turned out beautiful and it looks like I see it for sale now on Craigslist.
Thanks, Darrel 202-468-6105
Darrel
My Varmint build
Probably the best advice I can give is to use a good product. Dupont Imron clear is what was recommended to me but it wasn't available in my area so I went with what the local auto paint supplier had which was a PPG product. It looked great for several years but then started to flake off again. The clear I used was for cars. PPG did have a product meant for boats but they didn't have it in stock and it was really expensive. If I had it to do all over again I would have used the better product. I found it real easy to remove the existing clear coat with a simple razor blade. Scuff up the old gelcoat to give the clear coat some tooth to bite into, mask, clean, and spray the new clear. I believe I sprayed 3 coats but it will be whatever the manufacturer recommends.
Imron is nasty stuff to work with so make sure to wear a good respirator, gloves and suit.
My Varmint build
Thanks for the advice. I am still doing research and have found a few fiberglass shops that know what they are doing and aren't unreasonable. I know my limitations, and paint is something I suck at (mechanicals are no problem).
Darrel
- 3790 Views
- Last post by terry2
Oct 03, 2015 10:39 pm
- 4288 Views
- Last post by bill6ft6
Mar 06, 2017 8:51 am
Design it, Drive it : Speedboats (simulator/video game)
Last post by Todd Wasson « Sep 24, 2015 9:11 pm - 29Replies
- 16276 Views
- Last post by Todd Wasson
May 05, 2017 5:14 am
- 3656 Views
Oct 03, 2015 11:04 pm
- 3146 Views
Oct 04, 2015 8:10 pm
Users browsing this forum: No registered users and 65 guests
